Performance upgrade...
Old Jul 31, 2002 | 08:40 PM
BlueTrane's Avatar
Post Performance upgrade...
For those of you interested in more horsepower, have you ever considered an ignition amplifier? I have no idea what it does or is but a friend of mine has one on an old Volvo swears he gained lots of performance from it.
Does anyone have any experience with one or have tried one? I know they're poplular with the import crowd. Maybe there are benefits to our power hungry egos.
Any info would be great!!
Old Jul 31, 2002 | 09:07 PM
asudan96Runner's Avatar
These are really only necessary on high compression vehicles, or ones with turbo's and superchargers. The stock coil produces plenty of spark on a stock truck, but the higher compression s/c'd trucks and turbo cars can cause the spark to "blow out" and not ignite the gas as well.
Import guys buy them because they look cool.
Dan
Old Aug 1, 2002 | 04:06 AM
jacksonpt's Avatar
Senior Member
I think I remember reading some of Gadget's comments on this subject. Apparently he considered doing it but was told that the ignition system that comes on 3rd gen runners is one of the best stock systems available. Gadget was told that it was not necessary to upgrade the ignition system because it is so good. Do a search over on the OW board... the thread was pretty recent, within the last week or 2 I believe.
Old Aug 1, 2002 | 09:58 AM
Krash's Avatar
what about 2nd gen pickups?
Old Aug 4, 2016 | 06:40 PM
707yota86's Avatar
Got a little behind on posting on here but got the block and down other parts back from the machine shop.
Hammered black valve cover
Block bored .020 over and cleaned
Crankshaft ground .020 main .020 rod
New rod bushings and rods cleaned
Stainless steel freeze plugs
Ok so I got the crank in but I have a problem..the crank won't turn, turns slightly when cap bolts aren't Torqued all the way. Anyone know what's causing this?
Old Aug 4, 2016 | 06:42 PM
707yota86's Avatar
Not sure what happened but my thread got posted on yours sorry
Old Aug 7, 2016 | 07:30 PM
vasinvictor's Avatar
One of these things is not like the other, hahaha. Our stock ignition system works great all the way to at least 14psi... that's as far as I've personally taken it anyway, but I'll bet it would be fine up to 20+. No need to upgrade anything!
Iceman4193
Oct 16, 2015 10:50 AM
kbpickens
Oct 2, 2015 03:37 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
user 82300
Sep 22, 2015 07:00 AM
