The Perfect Power SMT piggyback controller
Old Jun 21, 2006 | 05:28 AM
  #161
midiwall's Avatar
Psssssssssttttttttttt... Lookie what I just tripped over:
http://www.bobblick.com/techref/proj...sim/o2sim.html
The lead-in is here:
http://www.bobblick.com/techref/proj.../o2sensor.html
Bottom line, it's an oscillator used to fake the O2 sensor signal so that you can adjust the closed loop tuning. It _replaces_ the O2 sensor, not just pggybacks it.
Old Jun 21, 2006 | 02:24 PM
  #162
Weasy2k's Avatar
If you wanted to do that the SMT6 does that already ....
It doesnt really talk about open and closed loop and how the thing switchs it into open loop....unless i miss read something...which would not surprise me...
Old Jun 21, 2006 | 03:59 PM
  #163
rimpainter.com's Avatar
Sorry to change gears for a second guys, but I have a question: Is it somewhat accurate to use the AFR % on the SMT at WOT? I was out retarding my timing again the other day, when I decided to look closer at this feature. While in second gear at about 2K, I floored it and took it almost to redline. Most of the time the AFR was in the low 14's. I assume that's pretty good if the SMT is accurate. Thoughts?
Old Jun 21, 2006 | 04:06 PM
  #164
midiwall's Avatar
Ummm, man it's been a while. The SMT is hooked up to the O2 output, right? If so, then yeah, it should be accurate.
But if that's accurate, then you're running LEAN - WOT A/FR should be 12.5:1 - 11:5:1. The sweet spot will vary based on a number of things, but 14:1 is too lean.
and! (here's a segue for ya'!) check your email at cox.net, I bought 370's, so the 305's can be yours.
Old Jun 21, 2006 | 04:09 PM
  #165
Doh! No more LEAN! OK cool, I will check my email right now. BTW, I will be up there July 15 thru July 23.
I am thinking about making another "get together" post. Maybe this one will work better.
Old Jun 21, 2006 | 04:11 PM
  #166
midiwall's Avatar
Dood... when are you getting in on the 15th?
https://www.yotatech.com/forums/f15/07-15-2006-reiter-trails-play-day-wattora-87225/
Old Jun 21, 2006 | 04:14 PM
  #167
Let's take it over to email Mark. But the answer to your question is 9:30AM. My parents would kill me if I took off on that day unfortunately.
Oh, my wife would too.
Old Jun 21, 2006 | 05:17 PM
  #168
Weasy2k's Avatar
Woot party!
I wouldnt trust the afr ont he screen..you have to keep in mind that the narrow band does not show the true values...i have tested this against my wideband and when i was at 11:1 the smt6 read 14 then 10 then 13 tghen 11... to random...
Old Jun 21, 2006 | 06:33 PM
  #169
OK, I feel a little better. But I am still buying Mark's 305's.
Old Jun 22, 2006 | 12:05 AM
  #170
Weasy2k's Avatar
what injector syou have?? stock?
IF so then your def hitting the 14 areas I barly use my 370's
Old Jun 22, 2006 | 05:01 AM
  #171
Yeah, stock here.
Old Jun 22, 2006 | 01:01 PM
  #172
blink's Avatar
my 305's are sitting a box not being used :*(
Old Jun 22, 2006 | 01:07 PM
  #173
blink's Avatar
did you install a wideband sensor? im pretty sure the 96's use a narrowband o2 sensor which at WOT is useless for determining a/f ratios
Old Jun 22, 2006 | 01:28 PM
  #174
Doug! You have 305's? Doh! Why didn't you tell me that before!?
Old Jun 22, 2006 | 01:45 PM
  #175
midiwall's Avatar
I don't have a problem if you want Doug's instead. Just lemme know!
Old Jun 26, 2006 | 08:12 PM
  #176
Weasy2k's Avatar
yep Up until 99-00 ish
Old Jun 27, 2006 | 08:34 AM
  #177
blink's Avatar
Johnny! when are the smt 7's going to be in stock!?
Old Jun 27, 2006 | 11:20 AM
  #178
Weasy2k's Avatar
the smt7's are order on demand basis...i dont stock them right now just because I am putting the cash flow from the company into R&D That and the supplier is currently out should be mid aug before they see them at which point ill be ordering some for stock. i want to do more tests with it.
Old Jun 28, 2006 | 04:52 PM
  #179
blink's Avatar
i need it for r&d 2
Old Jun 28, 2006 | 10:07 PM
  #180
Weasy2k's Avatar
haha we all do modding is non stop R&D
