Overheating issue .........
Old Aug 9, 2008 | 02:10 PM
ozziesironmanoffroad's Avatar
know whats weird? i havent had my shroud in over 100,000 miles, and i havent ever overheated, even in vegas. so weird.
Old Aug 9, 2008 | 07:49 PM
jaybur_racing's Avatar
here is a photo of the 'Runner that is getting a little hot under the collar. I just got those TRD tacoma rims for $200! and then bought the Kumho Kl71's new.
Old Aug 10, 2008 | 01:54 PM
okie81's Avatar
Mr. Gasket Block Check(as mentioned above) works great; saved me from spending a lot more that I did.
Old Aug 11, 2008 | 03:21 PM
surf4runner's Avatar
try a leak down test on the rad to confirm a good HG.
no mention of any coolant loss...
i suspect the rad too.
Old Aug 11, 2008 | 08:48 PM
  #25
well I will know soon enough! I will update once its installed
Old Aug 11, 2008 | 09:43 PM
  #26
Ritzy4Runner's Avatar
Just afoot note for you. I don't know what brand of antifreeze you are using but I have been using the OEM toyota antifreeze, (its the dark red color) which I know can be a bit spendy, but I have not had any issue with my cooling system using that coolant in my system. (check out my trip report to California and back) https://www.yotatech.com/forums/f2/t.../#post50896330
I actually ran the truck for over 150 miles including stop & go traffic, mountain pass climb to 4000 feet, and then valley running with outside air temps from 80 to 103 degrees with the AC running when the temp got over 90 and I had the electric fan turned off accidently, no over heat, no boil over.
If your system is overheating there is definitely an issue with the cooling system. I noted as well that there wasn't any mention of coolant loss or if there was you didn't mention how much you have had to replace. Seems like something somewhere is clogged or blocking coolant flow. Good luck on the fix.
Old Aug 19, 2008 | 05:04 PM
  #27
Update !!
well, the shop was right. I finally received my new radiator today, got it installed and then I made the drive up the mountain for the TRUE test.
and I am happy to say that the temperature needle never even budged from a hair below the halfway mark.!!
It was kinda hard for me to believe that the radiator was the problem, with only 14,000 miles on it. But this was a lesson for me, that just because something was recently replaced, does not mean it can't be the problem!
Oh well, it was a good excuse to do the water pump and timing belt.
the1998sr5
15
Jul 14, 2020 08:35 PM
the1998sr5
27
Nov 17, 2015 09:30 AM
TJWilly
Jul 31, 2015 02:05 PM
Logz808
Jul 26, 2015 07:09 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
