Are OME Packers nessessary????
Old May 28, 2003 | 05:25 PM
David's Avatar
I just ordered OME 881 for the front and 891 for the rear, but do you think that i should order the OME 95pfs packers for the front to even out the lift, or will it not be nessessary
thanks in advance
Old May 28, 2003 | 06:13 PM
Ranski's Avatar
Based on my experience I would say yes. I'm now running 882's after adding a winch.
Old May 28, 2003 | 06:28 PM
TDiddy's Avatar
I second that. I'm using them with my 881's.
Old May 28, 2003 | 06:36 PM
turboale's Avatar
Hum.... I think I missed them... What are they? I have noticed that the front is lower than the rear with my OMEs installed and sebtled. There is plenty of space between the CV boot and the lower a-arm. I was reading on another thread talking about the SAWs and they said it was touching (and they were runnign OMEs in the rear) I need to get that figured out b/c I have a TJM on the way...
Old May 28, 2003 | 06:46 PM
TDiddy's Avatar
They're metal rings that, if I remember correctly, sit between the shock and the cup. You may want to order a few of them, because they're only like 1/8 of an inch thick, if that.
Old May 28, 2003 | 08:27 PM
White SR5's Avatar
Which is better?
Hmmm... so which would be better, and which would be cheaper: Adding a 1" or 1.5" spacer up front along with 881's or a butt-load of trimpackers?
Zach
Old May 28, 2003 | 08:41 PM
TDiddy's Avatar
Well let me clarify: I wasn't using the OME trim packers to bring the front up to the height of the rear. If that's what you want to do, then go with a spacer. I don't mind the slight difference in front to back height.
I'm using (and I think this is what others use them for too) the OME packers to even out a slight difference in front height between the DS and the PS.
Old May 28, 2003 | 10:03 PM
David's Avatar
i thought that the only issue was the level from front to back, are you saying that there is also an issue from left to right
Old May 29, 2003 | 12:29 AM
mpampo
Guest
Posts: n/a
I got the 881/891 combo and have one 5mm packer on each side, the ass end looks higher but cant really tell unless you know that the ass end is higher. If I could do it over, I would get the 882s for the front and maybe an 892 if it's made for the back.
Old May 29, 2003 | 07:12 AM
TDiddy's Avatar
There's SOME difference in left to right. Its definitely less than the front to back difference. We're talking under an inch. But I bet alot of people do have a slight left to right difference.
That's another nice side benefit to SAW's - you can dial in different amounts on each side to compensate for this without using packers.
Old May 29, 2003 | 08:36 AM
4runner4me's Avatar
I used a 1inche cornfed spacer with mine upfront, Every one said that the cornfed were the only ones that would work with the ome. If i could do it all over i would get a 1.5 inche spacer would be perfect.
ZGjethro
Jun 7, 2017 11:04 PM
Scottcrb
Mar 3, 2016 11:57 AM
A2theK
Oct 14, 2015 07:10 AM
Swampwalker
Oct 12, 2015 09:49 AM
justdifferentials
Sep 5, 2015 06:52 PM
