OME lift Spacers Question?? please help new to this
Old Dec 4, 2003 | 02:17 PM
4runner265's Avatar
I have a 98 runner with the ome lift on all 4 corners and one very thin spacer on each front, Can i add more spacers with out taking the entire assembly apart, could someone send me a pic of what there setup looks like with spacers.
My spacer is right under the bolt for the entire assembly, up on top, is this right, I had my toyota dealership put the lift on
please help
Old Dec 4, 2003 | 02:24 PM
doink's Avatar
someone with more knowledge than me on the 3rd gen runner will chime in soon i believe. just wanted to say welcome the forum
Old Dec 4, 2003 | 02:25 PM
XtremeOff-Road's Avatar
Hi there, welcome to the board, I believe you are talking about the OME trim packers...Thin yellow spacers right?
Are you needing more lift? Are you wanting to place some more trim packers in the front? If so, you will need to remove the coil and strut assembly to complete.
Hope this helps!
Mike
Old Dec 5, 2003 | 06:51 AM
Dr. Zhivago's Avatar
Away
And to put my 2 cents in, the front OME Trim Packers go UNDERNEATH the lower spring seat. They do NOT go on top tof the spring assembly like all other spacers. So, the whole front assemblies will have to be dismantled to install the front OME Trim Packers.
They are not yellow, but instead little donuts of zic-plated metal. The go around the shock body and in between the lower spring seat and the bottom spring seat stop that is part of the shock body.
I found this out the hard way. Even an OME dealer didn't know this.
Hope this helps.
G
Old Dec 5, 2003 | 07:27 AM
Hope this helps.
G
Are you referring to me as the OME dealer who did not know this?
When he was referring to having OME in all 4 corners I was thinking he was wanting to add some to the rear now that he has them up front. The rear ones are yellow...
Mike
Old Dec 5, 2003 | 08:32 AM
RTdawgs's Avatar
Rear trim packers are "plastic" and yellow.
Front trim packers are "metal" and metallic in color.
Was the spacer you put in 5mm in thickness and described as above?
If so, and it was put on top of the assembly, it was put in the wrong place.
tradditional spacers are put in like this:
http://fastq.com/~sschaefer/front.html
Old Dec 5, 2003 | 01:57 PM
Away
Mike
No, not at all Mike. I bought some from a local OME dealer who didn't know what was what. I even spoke with ARB in Seattle before buying them and they didn't understand the application either.
I know you know what's what.
Peace.
G
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
ksmudrunner99
Jul 21, 2015 05:33 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
