OME Lift and Alignment Specs Questions
Old Mar 2, 2007 | 08:34 AM
Bandit Runner's Avatar
I am planning on getting the all OME lift front and rear (haven't purchased yet). I won't be able to intall it myself, so I called a few local shops for a quote on installation and an alignment. The quotes were coming in at around $400 ($330 for installation and $70 for the alignment).
First question: Does this sound like an average installation price? What should the installation cost?
Second question: The shops said that they needed new alignment specs to put into the computer because the ride height changed. So does OME provide new alignment specs with its springs? If not, will the factory specs be sufficient? What problems could arise using the factory specs to align to?
BTW, I searched extensively, but couldn't find specific answers to my questions.
Thanks for any input/experience you may have!
Old Mar 2, 2007 | 08:38 AM
KyleT's Avatar
I Had mine done to OEM (toyota) specs
Old Mar 2, 2007 | 08:40 AM
MTL_4runner's Avatar
Ditto.....price sounds more or less ok, have the shops do the install and then bring it to the dealer for an alignment.
Old Mar 2, 2007 | 09:34 AM
UNR.Grad's Avatar
Take a look at this thread for alignment help...
https://www.yotatech.com/forums/f123/alignment-issues-cant-get-your-rig-aligned-after-lift-info-81538/
Old Mar 2, 2007 | 11:16 AM
Yeah, I saw that thread when searching. Great info and I learned a ton, but it doesn't get into the issue of using the factory specs with a lifted rig.
Thanks though.
Old Jun 6, 2008 | 07:26 AM
Ron Helmuth's Avatar
thanks very much
I am a week or so away from install and this was most helpful.
Old Jun 6, 2008 | 08:57 AM
kmcaprice14's Avatar
Do it yourself... you can do it! Then you'll have $400 to spend on some other mods!
But before I sacked up and did mine myself, I had gotten shop quotes ranging from 275-500. Yeah, its nuts.
Old Jun 6, 2008 | 09:51 AM
b88miller's Avatar
+1
I had not done any suspension work prior to installing my OME lift. I did end up paying about $60 to have my front coil/shocks assembeled as well as a computer alignment. If you have time do it, you'll surprise yourself!
Have a good weekend!
coffey50
Jul 28, 2015 10:55 AM
MTLroadierunner
Jul 20, 2015 03:07 PM
hangtown88toy
Jul 10, 2015 02:33 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
