OME 880 and 906 with Bilstein Shocks
Hello everyone,
A few months ago I installed 4 new Bilstein shocks (set of 4 F&R #BE5-F332-H0 FR. #BE5-2451-H0 REARS) in hopes of fixing the loose, sloppy, bottoming out rear end of my 2000 4runner. Now I'm to the point of buying new coils and have been eyeballing the OME 880/906 combo.
I have searched and have found a ton of information on both parts, but little info about the combination. So a few questions:
1. Will this combination of shock and spring be ok?
2. How much lift should I hope for? 1"-2"?
3. Will this stop the horrible bottoming out? I don't think i can handle hitting those bumpstops anymore!
4. Would you recommend me buying a few 5mm trim packers just in case i need them? Will my new ride sit level with just new coils?
Thanks in advance for your help! Now it's off to the picture thread!
So, I take it the shocks alone did not help with your issues? I have the same problem with my `97 4Runner, it is dangerous hitting a bump in a corner, the back of the truck ends up beside me everytime. So i would love to see what you find out about rectifying this issue on your truck.
yeah, the famous rear spring sag issue on 3rd gen's...
My 97 has those "trailer" bushings, dont remember the manufacturer, that install on the frame above the rear axle. They are supposed to help with control while trailering, and werent supposed to contact the axle until you loaded the rear.
Ha ha, yeah...as soon as I lowered the truck down onto the new bushings, they were already touching UNLOADED.
Well, I've driven like that for 6 yrs now
ride is a bit stiff, but no sag, ha ha...and lots of control while trailering...I also have a sport shock installed that also stiffened things up...but shocks arent supposed to control compression, that really is the job of the coil.
Anyways, now I dont trailer with it anymore, and am looking for a solution. I would like to buy a replacement spring, with no lift, but that doesnt immediately start sagging excessively like the original ones do.
So....I'm watching this too
I would not go with the Bilstein OME combination. I used to have Bilstein HD shocks with stock springs but now I've got the OME springs you mentioned with OME shocks. I can only imagine how stiff the ride would be. But the 906s should solve your bottoming out problems. They are pretty heavy duty compared to stock.
why not just spacer the stockers?
You might be okay with your Billie's and the OME springs, I don't have any experience with those. The HD's would probably be terrible with the OME springs though.
Another option is airbags for the rear springs. I used to run them and they were nice. The only problem I had is they would start leaking after a couple of years. Possibly due to dirt and mud getting trapped between the coil and the bag and wearing on the bag...
Im not going to lie
the 880/906 + Bilstein HD ride is stiff, but the higher rate springs then OE or 99 tall really do result in a nice responsive, and stable ride. I ended up with a 1.5 (f) to 2"(r) lift and about a .50" rake. I chose the 906s b/c i dont tow anything regularly, but wanted something that would let me if i wanted too. Combined with 275/75/16 Hankooks i like the ride on-road alot and it can be somewhat jarring off road depending on the conditions.
You might think about the 1999 factory springs. They should be a tiny bit taller than the 97 springs. Other than that, the Performance Products 1" lift springs would probably be your best bet but I heard that they don't make those anymore unfortunately.
yeah, air bags do usually end up leaking...so dont think I'll go with that headache.
Sounds like 99 springs might be the closest to stock.
Ok, I'm inches away from ordering the OME 880/906 springs but wanted to make sure there were any other problems this might cause, like the more severe driveshaft angle and such?
I'm thinking 1 to 2 inches isnt enough to cause any other complications, but wanted to make sure.
I installed the 881/906 combo and it is awesome with the Bilstein shocks (see first post for model #'s)! The coils probably gave 2" of lift since the rear coils were so shot. The ride is a little stiff but it is perfect for the washboard gravel roads. The street manners are good too! Next up is replacing sway bar bushings and maybe the panhard bar, then some 265/75/16 BFG Mud Terrains, and some armor, and.........
I was wondering exactly were the specifications on the shocks and how you like them compared to stock?
Did you do the work yourself? If so did you run into any issues?
Thanks
I thought I would be clever and piece meal my package together using stock replacement Bilstein shocks with the OME springs. In hindsight I should have ordered the OME Comfort shocks to compliment the springs. I assumed a 2" lift wouldn't change much, but now I feel the stock shocks are out of their sweet spot.
I really don't need high performance gas shocks I would like to find nice set of conventional shocks for a good price that would work with the 880 and 906 springs.
How did you know the Bilsteins would work with the OME springs, in terms of size, travel and fitment?
