ok so what does everyone use for...
gas octane? is 93 worth it?
fuel injector cleaner? does chevron techtron(in a bottle not gas pump) work?
standard(nonsynthetic) motor oil? do brands matter? whats best?
any good oil or gas additives? (slick50, duralube type stuff?)
whats the best tranny fluid?
I use whatever octane it says in the owner's manual. Prior to putting on the S/C I used 87 Octane (like it says in the book). Since the S/C install, I use the 93 Octane. I will throw in a bottle of the Techron once per month and use BG44K about every 10K-15K miles. All my other fluids (diffs, tranny, oil) I use AMSOIL.
Avoid any of those fuel/oil additives,nearly all are a joke,just use a good brand name oil whether it's dino or synthetic.
I use a can of BG's 44K in my fuel system once a year,it is kinda pricey but better works.
One additive that you may wanna look at is Auto-RX. A couple of folks here are running through the process now:
https://www.yotatech.com/forums/f2/clean-engine-healthy-engine-27478/
Yes, the Techtron does work to clean the injectors so do use that.
I use dino oil but many are using amsoil brand with much success.
I second the Auto-RX, I am not using it but from what I have seen it works very well.
Here in Colorado there is no such thing as 93 octane (high altitudes). I use 87 or 91. I also put a can of BG 44K in once a year. As far as fluids plain Valvoline motor oil and BG oils for the tranny, and diffs.
For me - High octane, Mobil-1 in the motor, Amsoil everywhere else.
Techron in the bottle is the way to go.
As for non-synthetic oil I'd stick with a name brand. Castrol, Havoline, and Valvoline are good choices. But why use old technology when you can get Amsoil with 7500 drain intervals??
I use 87 in everything I drive.
I run pennzoil w/ schaefers moly additive. (the additive is not a joke, Ive used it in several vehicles and its never failed to extend the life of the oil. As in when they would start to use a little oil around 4k miles they now run to 5 or 6 without using a drop)
We used to sell the heck out of Techron cleaner with lots of positive results.
rattlewagon
Apr 13, 2013 06:59 AM
Scottdanpor
Dec 7, 2011 03:01 PM
