Oil Pump Replacement Interval?
Old Nov 29, 2004 | 03:06 PM
Bumpin' Yota's Avatar
My truck has 256,000 miles on it and I may have to tear back into the front of the block to rectify a suspected waterpump leak. If and when I do, should I swap the oil pump?
I can do an oil pressure check, but the guage is showing good pressure at startup (cold) and low normal at idle (hot) and at highway speeds its upper limits of normal..... Thoughts? Should I swap it out or let sleeping dogs lie?
Old Nov 29, 2004 | 07:31 PM
yamarocket630's Avatar
Oil pumps run in a constant oil bath, and run under very light/constant load. As long as your oil is clean, the wear is usually not enough to worry about at any mileage. Run dirty oil too long and it's a different story.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
Avenged
Jul 9, 2015 07:55 AM
Jnkml
Jul 6, 2015 01:20 PM
