Oil Pressure Gauge
Old Feb 20, 2004 | 02:01 AM
Oil Pressure Gauge
Hi i have a 1989 4runner with the 2.4L and i want to put in a sunpro oil pressure gauge but dont know were i would hook the oil line up to could someone help me if they hooked one in before thanks
Brad
Old Feb 20, 2004 | 02:18 AM
Yoter's Avatar
Guest
Never messed with a 2.4 litre but look on the side of the block. I think normally on the oil filter side. Its a golf ball size part that screws into the block. It has a wire coming out of it that ends up going to your guage in the dash. I think this is all correct. I double checked in my Chilton manual but it doesnt help. Good luck. Blue
Old Feb 20, 2004 | 02:58 AM
foxtrapper's Avatar
Guest
Like the other fella said, the location of the idiot light sending unit is on the passenger side of the block. It's near the oil filter.
You can simply remove that sending unit and install the fittings supplied with the gauge into the hole. The idiot light will now be dead.
If you want to keep the idiot light, you've got to go to a hardware store and pick up a t-fitting that will thread into the block. Then you install the idiot light sending unit on one arm of the t, and the gauge line or sending unit on the other arm.
Brad
Old Feb 20, 2004 | 04:25 AM
Arnold's Avatar
Smile
There's also another port that can be used behind the front pass side motor mount.
Old Feb 20, 2004 | 12:29 PM
thanks guys thats a big help hopefully when i install it i will get some pics and show it all to you but thanks for the help
Old Feb 20, 2004 | 12:50 PM
3.4v6's Avatar
there should be like 2 extra ports by the oil fliter. thats how it is on my v6
Old Feb 20, 2004 | 03:08 PM
86toyota's Avatar
That's how I did it on my 2.4 ,used a tee.
how do I get a bigger pic to post?
Old Feb 20, 2004 | 03:30 PM
Krash's Avatar
Just wanted to say that T-fitting is a really good Idea.
Old Feb 22, 2004 | 02:22 PM
I didnt do the T becuase u i didnt really think my siwtch i took out worked neway but i got it in the one by the motor mount next to the oil filter on the bottom ill take some pics and show you the mounting of the oil pressure and the volt gauge i think for a cheap way of doing it it looks really good but thanks alot for all the help
BRad
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
