Oil cooler
Old Aug 25, 2006 | 05:33 PM
QSVeilside's Avatar
Oil cooler
Did a search...
Lot of info on tranny coolers... not so much info on oil cooler kits, (mainly for turbos so I wouldn't expect as much).
Does anyone know of a kit for our trucks? Being supercharged, I'd like to bring the oil temp down a notch.
Old Aug 25, 2006 | 06:20 PM
seanz0rz's Avatar
Guest
being a non supercharged vehicle, id still like to drop mine. heat is the enemy, anything to help would be good,
very interested also!
Old Aug 25, 2006 | 06:44 PM
frodin1's Avatar
Seek and ye shall find. Hayden coolers = same as TRD.as I was told here. There are many options available. IPT and B&M also have been mentioned. Just depends on how large and how much you want to spend. I have the Hayden 678 on my 2000. I paid $55 on ebay and used the ties for the install. Purchased more tranny line and shielded everything in Kevelar Hyd. hose wrap. Very clean install that doesn't take very long. My.02cents
Old Aug 26, 2006 | 05:32 AM
mt_goat's Avatar
You know the 3.4 already has an oil cooler right? It is cooled by the engine coolant so a cooler thermostat will help with cooling the oil. You don't want to cool the oil too much, especially you you take a lot of short trips. The water doesn't get boiled off.
Gadget did some testing with his SCed 3.4 and a oil temp gauge and said the stock oil cooler works fine.
Old Aug 26, 2006 | 05:38 AM
mt_goat's Avatar
We talking engine oil coolers or ATF coolers?
Old Aug 26, 2006 | 06:00 AM
mt_goat's Avatar
Just so we're all on the same page, the stock oil cooler on the 5ZVFE can be seen in this pic. Follow the cooling hose that runs from the thermostat area over the oil filter over the motor mount and into the oil cooler. http://community.webshots.com/photo/...42310107BbLKRD
It can also be seen on the right side of this pic (without the cooling lines attached):
Old Aug 26, 2006 | 06:17 AM
4x4Lamm's Avatar
If you want just a little extra cooling, get an oil filter relocation kit (adds about 1 qt capacity) and then put a cool-collar heat sink on the filter. Cheap and easy.
Lamm
Old Aug 26, 2006 | 08:49 AM
frodin1's Avatar
My bad, I figured he was talking about ATF cooler kits. Not engine oil.
Old Aug 26, 2006 | 12:04 PM
QSVeilside's Avatar
Thank you for the advice guys.
MT- Thank you for the pics and advice. I didn't even consider the thermostat! With the TRD 160 thermostat, (comes with the 7th), maybe I shouldn't fool around with this after all.
Old Dec 8, 2013 | 09:08 PM
coolranchluke's Avatar
Lamm
What ever happened to the cool collar? It seems like the company discontinued the product. Anyone know the story?
Sorry to jump in about eight years later, but I'm curious.
Old Dec 8, 2013 | 09:14 PM
Lamm
Old Mar 20, 2014 | 06:49 PM
stovetop36's Avatar
It was discontinued but, can't seem to figure out why. There are many pages saying that it worked quite well. There does seem to be some other companies making similar products though. This is the only link I could find for one that might actually work. Maybe
Amazon.com: Purple Engine Oil Filter Cooler/Heat Sink Cover/Cap Billet Aluminum Kit Ef Eg: Automotive Amazon.com: Purple Engine Oil Filter Cooler/Heat Sink Cover/Cap Billet Aluminum Kit Ef Eg: Automotive
Old Mar 20, 2014 | 08:34 PM
Rowdydudeman's Avatar
I picked up an oil cooler from a celica, runs coolant around the collar. very similar setup thats on a lot of newer cars too. that's really the best way to cool it also, colder oil is more viscous and lubes like ˟˟˟˟ but if its to hot it breaks down and doesn't lube enough.
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
this_guy
Jul 31, 2015 01:27 PM
calderp
Jul 27, 2015 09:58 AM
Coreyr384
Jul 10, 2015 11:13 AM
Snort
Jul 9, 2015 03:58 PM
