oil consumption
Old Dec 15, 2004 | 07:01 PM
93bluetoyota's Avatar
oil consumption
Hi, I just changed my oil 1000 miles ago. Today I checked my oil level and it was down too the fill line. I double checked the the drain plug and it was not leaking at all. I also checked the oil filter that too was tight and not leaking. The truck doesn't leak at all. No spots in my driveway or anything. What could it be? I need some help fast!! Thanks a lot
Tyson
Old Dec 15, 2004 | 07:31 PM
Yamaha+Toyota=Fun's Avatar
Check out you coolant and see if it is discolored at all.
Old Dec 15, 2004 | 07:34 PM
What does it mean if its discolored?
Old Dec 15, 2004 | 07:50 PM
PirateFins's Avatar
If you pull your oil dipstick and it looks like chocolate milk then you have coolant mixing with the oil. You will also see this in the coolant but not as noticable.Bad head gasket or a timming chain that has broken thru the water pump.
Also drop your skid plate and see if you have any oil on the bottom of the motor (front main seal leak), or you could just be burning it.
Old Dec 15, 2004 | 11:13 PM
jimbo74's Avatar
you cahnged your oil 1000 miles ago.. did you do it personally or have a shop do it? and do you know for a fact that it was full? most times, its not really that you lost it, but that it never was full to begin with
Old Dec 16, 2004 | 10:47 AM
tpg013's Avatar
Junior Member
What engine do you have? On my old 3.0 I had the same concern. I asked the dealer and they said it was normal for the 3.0 to consume one quart every 1000-1200 miles. I confirmed this with Toyota USA. I have the 3.4 now, no problems.
Old Dec 16, 2004 | 11:57 AM
PirateFins's Avatar
His sig says 22RE
Old Dec 16, 2004 | 12:39 PM
tpg013's Avatar
Junior Member
Originally Posted by PirateFins
His sig says 22RE
Didn't see that! :pat:
Old Dec 16, 2004 | 03:33 PM
I know I put enough oil in there. It takes 4 quarts and I buy the 1 gallon jugs that have 4 quarts in them and thats what I fill it with!!
Old Dec 16, 2004 | 03:35 PM
I was using full syn in mine with 190k miles. Ate that stuff up, even though there appearead not to be any leaks. I went with Mobil Syn Blend, much better.
Old Dec 16, 2004 | 03:53 PM
Yeah thats the thing is I'm not using synethic oil I just run Valvoline.10w-30
Old Dec 16, 2004 | 04:18 PM
jimbo74's Avatar
The Book Says My Truck Take 4 Qts Too... However Whenever I Do My Oil Change, Its Really Like 5-5.5 Qts That It Takes.....
Old Dec 16, 2004 | 04:22 PM
DanBUCF's Avatar
My 22RE in my '89 would eat a quart ever 1,000 miles while driving on the highway. Motor had 260K miles on it, consumed oil, but still ran strong (strong is a relative term or course).
Old Dec 16, 2004 | 04:47 PM
firemedic's Avatar
It is "normal" in that Toyota won't warrnty any less oil loss than that, it is "not normal", in that if you took a poll, most 3.0 owners probably do not lose near that much. It is a similar standard industry wide, I believe, basically a way to get out of expensive warranty problems.
Old Dec 16, 2004 | 07:47 PM
The the thing that worries me the most is the fact that when I got the truck with 110,000 miles on it it only burned about 1 quart every 3,000-4,000 miles. Now it needs 1 quart after 1000 miles? There has got to be something wrong!
Old Dec 16, 2004 | 07:49 PM
jimbo74's Avatar
again, are you sure its burning it? my truck doesnt burn a drop of oil, however i lose oil, the mechanical fuel pump has these 2 holes on hte bottom oof it, and for some reason, oil drips out of them?
Old Dec 16, 2004 | 09:32 PM
Well its heading to the shop soon cause its running like a POS. So hopefully I can get some suggestions on what it is!
Old Dec 16, 2004 | 09:35 PM
jimbo74's Avatar
running like a pos? have you done a tuneup recently?
Old Dec 16, 2004 | 09:43 PM
Yep thats the thing. I just had my mechanic look at it because it would idle very low like around 500 RPMs. It acted as if there was a fuel delivery problem. I cleaned my TB and that didn't work, so I took it to him and he found cylinder 3 had a clogged injector. He used so machine that hooks up to the fuel line, that mixes a strong detergent with gas and "eats" through the obstruction. After I got it back like a month later it started ding it again. I took it back and this time he found the MAF was dirty as hell so he cleaned it. He also checked the timing which he said was perfect, did a compression check which also was perfect, changed the plugs and wires, and did the cap and rotor! Now its running bad again. This time I think I will take it to the stealership or a "speciallty" Toyota shop to have them look at it.
Old Dec 16, 2004 | 09:48 PM
jimbo74's Avatar
it sounds liek this guy doenst know what hes doing.... have you done the fuel filter?
