Old Mar 30, 2016, 03:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Toyota Tacoma Tire Repair and Maintenance
Print Wikipost
OEM Tire Size on '98 Tacoma?
Old Feb 8, 2009 | 02:40 PM
roger's Avatar
This is a weird question, but can anyone tell me what the OEM tire sizes were for a '98 Tacoma 4WD? I bought the truck used with 265/75 R15 tires, which I have assumed was the original size. Now it's time to get new tires, and looking at Discount Tire's site they list the OEM base size as 225/75 R15 and the optional size as 31/1050 R15. So were the 265s ever offered on this truck, or did somebody put an oddball size on there before I got it?
TIA
Old Feb 8, 2009 | 04:00 PM
cackalak han's Avatar
Yes, all three of those sizes were either standard or optional.
Old Feb 8, 2009 | 04:19 PM
Yota Runner's Avatar
If you look at the door seal tag with you vin # and stuff, it should list the tire size that you truck was built with.
Old Feb 8, 2009 | 06:47 PM
As has been the case with the 4Runners, the door jamb stickers are unreliable. Actually, none of my 4Runners said the correct size.
Old Feb 9, 2009 | 11:13 AM
deltaclothingco's Avatar
the 265 75 15's arent being recomended from DTC because they aren't that commen of a tire anymore. You're better off getting the 31 x 1050 x 15. Less expensive and more options. Plus if you ever pop one then local shops will probably have most 31's in stock.
Old Feb 9, 2009 | 01:39 PM
cpizzle42's Avatar
Being a DTC tire tech, delta is right about the 265/75-15R Being a odd size. 265's were offered, but I think only on 16 inch rim sizes. Go for the 31's...
Old Feb 9, 2009 | 05:04 PM
roger's Avatar
OK...so exactly how different are the 31s compared to the 265s? Will it screw up the speedometer/odometer readings?
Also, anyone got tire recommendations? Right now I'm looking at BF Goodrich All Terrain T/A KO and Bridgestone Dueler A/T 693, which is pretty much what I have now except in the 265 size. Good/bad/indifferent?
Old Feb 10, 2009 | 07:53 AM
I worked at Americas tire for 3 years and just recently broke away. (atc is dtc) CAN21, CAN08,. go to tires.com and there is a calculator or search google for the official metric to high floatation calculator
metric is 265 xx xx
high float is 31 1050 15
Old Feb 10, 2009 | 08:37 AM
Umm, 31x10.5/15 is basically the same as 265/75/15's.
Old Feb 10, 2009 | 09:53 AM
atistang's Avatar
yeah there is less than a half inch difference
Old Feb 10, 2009 | 10:10 AM
Actually, not even that in some cases. IIRC, most 31x10.5 are not actually 31" tall. For example, BFG A/T's in 31x10.5/15 indicate an actual height of 30.7".
http://www.tirerack.com/tires/Spec.j...irePageLocQty=
Bridgestone REVO's are at 30.5"
Mathmatically, 265/75/15's come out to 30.7". Yoko Geolanders are at 30.7"
http://www.tirerack.com/tires/Spec.j...SR5GEOHTSOWLV2
I'm thinking when these "tire techs" look for 31's, they're not looking for the right size description.
Old Feb 10, 2009 | 11:59 AM
Exactly its like when I tell my girl that I'm 9" and im actually only about 3.75.
tires are almost never their actual measurment on the sidewall.
Flying91
45
Apr 11, 2024 04:39 PM
djpg2000
Nov 11, 2020 04:56 AM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Yotoder865
Jul 9, 2015 07:51 PM
