odd whining noise
Old Jan 23, 2011 | 08:24 AM
warpigg's Avatar
Question odd whining noise
my 4runner is a 5 speed and when im driving the higher the rpm i go it whine's louder and i have no idea what it is. it sounds almost like a super charger whine. if anybody could help me try to figure out what it would be that be great.
Old Jan 23, 2011 | 08:40 AM
xxxtreme22r's Avatar
have you check your transmission gear oil lately?
Old Jan 23, 2011 | 08:50 AM
warpigg's Avatar
no but im perrty certain its the engine and its 10 degrees out so im not going to look right now ethier lol
Old Feb 3, 2011 | 05:43 AM
sl0annuggets's Avatar
Where would you check that?
Old Feb 3, 2011 | 07:37 AM
justin_4runner's Avatar
from the dip stick in the engine bay. there will be 2 of them in there one oil and one tranny if its auto, manual tranny u need to pull a plug on the side of the motor.
now for the whining it could be a belt, or pulley bearing, also a vacuum leak, and then it could be a bad bearing or cam in the motor, so kind of need more info. is it from the front of the motor, have u tried to look under the hood and just giving it gas to produce the whining? let us know,
Old Feb 3, 2011 | 08:41 AM
txrunyota's Avatar
Do you have an aftermarket audio deck, speakers, subwoofer, amp? I have a whine that goes up with RPM based on interference with the amps. Just another possibility.
Old Feb 3, 2011 | 12:02 PM
warpigg's Avatar
i found out it was my alternator, are there any alternators i could mount that would be better that i dont need a differnt bracket for?
Old Feb 4, 2011 | 06:26 AM
My whine only happens when the truck is in gear. If I go into neutral, it goes away.
Old Feb 4, 2011 | 08:56 AM
guitarplayer360's Avatar
i have the same issue...i kind of like it though. gives it a cool supercharger sound effect.
Old Feb 4, 2011 | 09:13 AM
usually if you get a whine noise from your stereo its cause u have a bad ground or running your power wire and your RCA's next to each other
Old Feb 4, 2011 | 12:02 PM
warpigg's Avatar
mines getting worse every day and i need to know if there are any better alternators i can get that will fit?
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
