not starting
Old Jan 10, 2004 | 09:04 PM
flecker's Avatar
From: White Mountains, Arizona (Yes it does snow in AZ)
What MTL4Runner said... sounds about right to me.
Old Jan 11, 2004 | 05:35 PM
My99's Avatar
I concur. Pull the plugs and see if they're wet. If they aren't, then you know you're not getting fuel. Surely these trucks have an EFI fuse somewhere, check for that, then check the pump.
Old Apr 30, 2004 | 10:49 PM
86 TurboSR5's Avatar
Mine wouldnt start either. EFI Main Relay on my 86 was bad. I guess they go out just like a light bulb. Mine was in drivers bottom sid e panel.
Old May 1, 2004 | 06:55 PM
Blair's Avatar
Efi...
Try swaping in an EFI that you KNOW is good.
I'd bet THAt is the culprit. Your symptoms sound alot like an issue I dealt with back when I reversed the polarity on my battery, thus frying my EFI.
New relay ($30) and she started right up.
No EFI = no 'send fuel' message from the on-board computer.
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
