No. 6 Cyl Mis-fire in 1997 SR5 4Runner
Got in the 4Runner this am, started it and it was idling really rough then the check engine light came on. Found a close Autozone and their code reader said "No. 6 cylinder mis-fire"......so I bought a bottle of Lucas fuel injector cleaner and poured it in. But I was kinda far from home (120 miles away) so I headed back. It was highway the whole way but the engine was definately missing/shaking and the check engine light blinked a couple times. Once home, I picked up a brand new set of NGK 4302's hoping to fix the problem....still got a check engine light and she's still missing. :cry:
Anybody have any ideas before I get raped for $89 bucks at the Stealership to diagnose the problem? Any help is greatly appreciated!!!!
Thanks
Todd
Thanks
Todd
The 3.4 doesn't have a distributor cap and rotor.
Sounds like a bad coil pack to me. It could also be a wire that is exposed, so you might want to test that too.
Go to the TIS website for a $10 download of the coil pack/plug wire diagnostic procedure and then use a multi-meter to diagnose the problem. In the long run, you will save money over the $89 dealer charge (or whatever it is).
Originally Posted by celica
Had the same problem in mine & it was the cap & rotor, cheap to replace. My wires are original & still fine. Just lok at the wires for physical damage
Matt
Matt
they have 3 individual coilpacks on the passenger bank with slave wires going from them to the driver side bank.
Please excuse my ignorance....but where the heck is the distributor on these things?
All I see is a box on each plug on passenger side with a wire from each running to drivers side!?
Those coil packs are $$, so I doubt it. If it was a bad coil pack, the cylinder with the bad coil pack on it would be failing too. You should try moving wires around and see if the missfire "moves."
Or, you could just buy new wires and be done with it. No guarantees though.
Originally Posted by <96 Runner>
...I am pretty sure #6 is on the passenger side against the firewall, which means it has a coil pack on top of it. Don't quote me on that though.
https://www.yotatech.com/forums/f2/3-4l-firing-order-cylinder-designations-60178/
It is either wires or a plug would be my guess (coil pack usually gives a dual misfire but not always).
.....all 3.4L motors are ditributorless and have coil packs like these:
I doubt its the coil pack, I recently spoke witha old timer mechanic that was telling me in 50+ years of working on cars hes only seen 1 bad coil.
I would look at the wire, fuel injector, and plug(recheck it).
I recently had the same symptoms and it turned out my plug was cracked at the electrode.
Thanks Guys!!!!.....I just finished replacing the wires and it seems to be running fine again!
But the CEL is still on..... Do I need to have the CEL turned off or will it go off by itself......or worse....do I now have another problem?
They had to build a new coilpack factory to meet the demand for replacements. Well, it wasn't that bad, but so many failed there was a backlog of weeks for getting them replaced under warranty.
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
