newly rebuilt 22re won't start
Old Jan 2, 2005 | 08:51 AM
Coldforged's Avatar
I can't get my newly rebuilt 22re to start. I've checked the spark and there's gas at the main fuel hookup. I'm not really sure what to check from this point on. I'm wondering if the injectors need to be primed somehow but the factory manual doesn't mention anything about that. Any ideas?
Old Jan 2, 2005 | 09:13 AM
ttr125mar's Avatar
What kind of noise does it make when you turn the key? Also you might want to check the starter.
Thanks,
Mario
Old Jan 2, 2005 | 09:17 AM
Coldforged's Avatar
The engine turns over fine. It's definitely not related to the starter. The start up sound is normal except that the engine just won't catch.
Old Jan 2, 2005 | 09:22 AM
4Crawler's Avatar
You might try the fuel pump test jumper to let the fuel pump run with the ignition. Leave it on for a while to get the fuel lines filled:
http://www.4crawler.com/4x4/CheapTri...shtml#FuelPump
Old Jan 2, 2005 | 11:49 AM
RED 85's Avatar
Check your distrubuter make sure it is not 180 out and also that the cam is not off, double and triple check both of those, they can be a booger.
Old Jan 2, 2005 | 01:38 PM
the_supernerd's Avatar
Maybe try spraying some carburetor cleaner in the intake while cranking it. If it fires a little then you know that it is definitely fuel related.
Old Jan 2, 2005 | 03:14 PM
Coldforged's Avatar
Ha, the distrib was off 180. Started right up. Thanks for the help guys.
Old Jan 2, 2005 | 03:21 PM
RED 85's Avatar
You bet!! It happened to me!
Old Jan 2, 2005 | 05:22 PM
jimbo74's Avatar
as soon as i read that it wouldnt start but you had spark and fuel i imediately figured the dist was 180 off.... that happened to me last month when i did my headjob
Jun 1, 2021 01:51 PM
Regency
20
Jan 3, 2020 07:43 PM
Sandman
Jul 23, 2015 08:15 PM
Jnkml
Jul 6, 2015 01:20 PM
CJ94yota
Jul 3, 2015 10:14 PM
