New Tires! but....calipers touching wheels
Old Dec 28, 2005 | 03:02 PM
GodwinAustin's Avatar
I just threw on a pair of 32s MTRs on the truck (finally) with a pair of black steelies...everything is perfect with only a bit of rub at full lock BUT I noticed that the wheel is pressed against the caliper (pretty hard - enough so that the paint chipped off the inside of the wheel after tightening) I drove the truck about 160 highway miles today and didnt notice anything out of the ordinary other than the increased road noise from the MTRs....Braking seemed fine, but hell I am no expert.
anyways do I have to do something about the wheel and caliper touching or can it be left be if everything seems ok?
thanks.
edit: while searching it seemed like some people solve this problem by shaving their calipers...can I do this? any drawbacks? I love my black steelies and want to keep them!
Old Dec 28, 2005 | 03:08 PM
waskillywabbit's Avatar
Take the tires off, if they are indeed rubbing, you will see the marks where, grind off accordingly as it doesn't take much, then make sure to paint that spot or it'll rust.
Old Dec 28, 2005 | 03:16 PM
ahh, also how the hell do I actually shave the calipers - and how much can I shave before brake fluid starts flying all over the place?
Old Dec 28, 2005 | 03:18 PM
rngrchad's Avatar
I had the same issue with my eagle 589's. They rubbed the calipers. I didn't worry too much about it because the calipers removed the excess, and my rims fit great now
As for steelies, yeh, grind'm down a bit with an angle grinder or something of the sort.
Old Dec 28, 2005 | 03:20 PM
Albuquerque Jim's Avatar
Slowly shave it down with a 4" grinder. I'd use a flap disk. You only need to remove enough so they don't touch.
Old Dec 28, 2005 | 03:28 PM
since I am a total jerk, is it better to shave the caliper or the wheel?
Old Dec 28, 2005 | 03:34 PM
rngrchad's Avatar
Well, I let the caliper shave my wheel, however, you probably will have to shave your caliper. Not a big deal. You ain't gonna blow dot3 fluid on you unless you get WAYYY carried away with the grinder, shoot you could probably do it with a good hand bastard file. You'll just sweat a bit more with the latter.
Old Dec 29, 2005 | 05:04 AM
thanks for all the responses guys - I will grind down the rotors.
Old Dec 29, 2005 | 05:06 AM
Talking
CALIPERS
Old Dec 29, 2005 | 05:10 AM
ahh crap, yeah...those.
maybe I should just go back to driving my buick century station wagon
Old Dec 29, 2005 | 05:14 AM
lee's Avatar
lee
when youre done with that, come join NE4ROC!
we have a meet & greet scheduled for jan 14th
Old Dec 29, 2005 | 05:33 AM
I work most weekends.
prob wont be able to make it. But there is chance
Old Dec 29, 2005 | 06:11 AM
Yoda's Avatar
I mounted the large V6 Calipers on my Landcruiser. I had to grind a lot of the "fins" off the caliper to clear my wheels.
Old Dec 29, 2005 | 05:16 PM
Allright somehow it seems that two of the wheels fit the front and barely clear the calipers, while two do not....its possible that the PO overtightened the wheels or something and compressed them? or maybe they just came from the factory stamped differently - so anyways, now everythign is on and I didnt have to grind the calipers - but I was thinking instead of grinding, I would add a 1/8" wheel spacer when I have to rotate the two rear wheels (the ones that dont clear the calipers) up front...does anyone know where to find a quality (IE not pep boys) set of 1/8" six lug spacers?
what about longer bolts or nuts - if I added a 1/8" spacer would this be necessary? where could I find those longer studs/bolts if neeeded?
thanks!
Old Dec 29, 2005 | 05:25 PM
Localmotion's Avatar
Originally Posted by waskillywabbit
CALIPERS
LOL.
Flying91
45
Apr 11, 2024 04:39 PM
coffey50
Jul 28, 2015 10:55 AM
DrZero
Jul 13, 2015 09:59 AM
Yotoder865
Jul 9, 2015 07:51 PM
