New horn
Old Dec 31, 2003 | 09:20 AM
fooddude's Avatar
New horn
Hey guys i found a new horn at autozone and have considered buying it. It is called air trumpets and i think hella makes em. Ive tried searching because i remember a post about this a while back but couldnt find anything on horns. What i was wanting to know is if anyone has these. And are they loud, easy to hook up, and are they good quality. Thanks guys.
Oh ya and if anyone can find the link to that old thread could you please post it.
Old Dec 31, 2003 | 09:30 AM
Bob_98SR5's Avatar
Are you kidding me?
Bob
Old Dec 31, 2003 | 09:31 AM
4RUNR's Avatar
Guest
Search has been for a while now.
Old Dec 31, 2003 | 09:34 AM
fooddude's Avatar
I kid you not my friend. I typed everything i thought could have anything to do with a horn in and nothing.
Old Dec 31, 2003 | 09:39 AM
Bob_98SR5's Avatar
yeah that is true, the search has been kaput for a few days.
the fiamm's is probably what you are thinking about. corey and skyrat have them and then a bunch of us did the same. i have them too and they are much louder and have more 'authority' than my previous hella supertones which sound a little BMW-ish (but still loud).
bob
Old Dec 31, 2003 | 09:42 AM
fooddude's Avatar
how do you hook them up, do you take the stock horns off and just wire the new ones up or what??
Old Dec 31, 2003 | 10:23 AM
4RUNR's Avatar
Guest
If you want the full effect don’t use stock wiring. Stock horns are in the area of 3amps, and the very average compressor(s) I got drained upward of 20amps. You'll have a considerable voltage drop and delay using stock wiring.
Wire up at least 12 gauge from the battery and trip a relay with the stock wiring.
Old Dec 31, 2003 | 10:25 AM
Plays_with_Toys's Avatar
Only if you don't care about your hearing.
I believe there is a special way to wire them up, because toyota's horns are always live, and when you press the button, you are grounding it. By mounting the horns you are grounding it and supplying a hot wire... Unless these horns don't ground when you mount them.
Old Dec 31, 2003 | 10:33 AM
rimpainter.com's Avatar
I have them hooked up to my stock wiring with one of the two stock horns still intact (as back up). I love em. Dont get trigger happy though, you just might cause a heart attack.
Old Dec 31, 2003 | 11:44 AM
4RUNR's Avatar
Guest
Not on a '99. Mine used frame as ground and 12v coming off the wire.
Old Dec 31, 2003 | 12:01 PM
amusement's Avatar
Originally posted by Bob_98SR5
" ... and have more 'authority' " ... bob
"... respect my authority ... "
Old Dec 31, 2003 | 01:03 PM
Waterboy's Avatar
If you get the FIAMM's you can use the stock wiring. Before I hooked mine up I measured the current draw and it was around 3A so no problem there. Also I think it depends on year, and model as to what kind of sytem it uses. I have 12V coming down the wire to turn on the horns. Mine were really loud when I put them on but now they are full of water so I'm back to a crappy sounding horn until I pull them off and clean them.
Old Dec 31, 2003 | 03:32 PM
rwmorrisonjr's Avatar
From: Home: Aurora, CO; Work: The People's Republic of Denver
Any link for the FIAMMS?
Old Dec 31, 2003 | 05:17 PM
Brendan's Avatar
I'm pretty sure I had the exact hella horns you are talking about. They are definitely better than the stock "meep meep" sound, but they are too high pitched for me. The volume was nice though. I bought a set of wolo powerhouse airhorns on ebay. Very happy with these puppies.
have a listen
Old Dec 31, 2003 | 05:34 PM
Brendan's Avatar
Here's how to wire it up...
the relay (which should be included with the horns) will have 4 posts. they are labled 30,85,86,87. There may be one other post, but you don't use it.
post 30 connects to the positive terminal on your battery. use 12 gauge wire or better with an inline fuse within 3ft of the battery.
post 85 goes to ground.
post 86 connects to the wire that ran to your old horn.
post 87 connects to the positive post on the air compressor.
ground the negative terminal on the compressor. mount your horns and connect the air hose to the compressor and horns.
that's about it. it's a quick writeup. i can go into more detail if you need. i'm here to help.
Old Dec 31, 2003 | 06:48 PM
midiwall's Avatar
Beep...
My setup:
http://www.midiwall.com/4Runner/airhorns.html
Old Dec 31, 2003 | 07:02 PM
Waterboy's Avatar
I followed the flock when the first thread come around and found mine at Pepboys. I think I paid around $30 for both. The thread name was "Simple Horn Mod" but search isn't bringing anything up and I didn't subscibe to it. There was some pics on that thread.
Old Dec 31, 2003 | 07:22 PM
SkyRat's Avatar
HERE
is the thread I started on my Simple Horn Mod.
Since you have a 2nd Gen, you might want to check out and pay special attn to Corey's Tech Write Up on the same horns for his application...
mussy01
Dec 13, 2016 08:20 PM
xzen73x
Sep 14, 2015 03:00 AM
Curbstomp336
Aug 30, 2015 07:20 AM
ToyoToler
Aug 8, 2015 08:43 AM
jimkoz26
Aug 5, 2015 03:15 PM
