new coils/shocks=need allignment ??
Old Aug 17, 2003 | 07:53 PM
kaiberg's Avatar
i did my downeys and bils just a bit ago...is it necessary to get an allignment after this ? havent noticed any pulling or drifting or anything...figured id put it out there for you guys...thanks for the input
Old Aug 17, 2003 | 07:58 PM
Good Times's Avatar
a good rule of thumb is to always to do your alignment after you do any suspension work you might not notice any significant changes but all it takes is a small change and you'll definitely see some unusual wear on your tires.
Old Aug 17, 2003 | 08:40 PM
Robinhood150's Avatar
Did you crank your tbars at all? If so then yes you should get it re-aligned. If you didn't crank them then maybe, maybe not. The bilsteins are high pressure shocks which may have lifted the front slightly, and if they did, then yes you should get it aligned. If you don't get it aligned, then watch the tires to see if they wear funny.
I didn't get mine aligned, but I am using rancho shocks which are not high pressure.
Old Aug 18, 2003 | 12:35 AM
UKMyers's Avatar
I didn't get mine aligned and after 6000 miles no probs with my BF's. I didn't crank my Tbars just installed the Bils.
Old Aug 18, 2003 | 06:31 PM
kaiberg's Avatar
no t bar adjustments...after the coils and bils it is perfectly level...thanks for the advice...i think ill wait a bit and just check the tire wear for anything funky...
kai
Old Aug 18, 2003 | 07:37 PM
carpemanana's Avatar
I'd go ahead and do it- might as well swap out the steering stabilizer too since you upgraded the shocks. OME is an awesome unit to go with.
Old Aug 18, 2003 | 07:56 PM
kaiberg's Avatar
is there really that much of a better feel with the OME stabilizer over stock...?? my stock still feels solid and isnt leaking or anything...
Old Aug 18, 2003 | 10:55 PM
UKMyers's Avatar
I noticed a big differnce with mine but mine was leaking and I'm thinking wasn't in very good shape.
Old Aug 20, 2003 | 08:25 PM
Mine was totally blown out and I didn't even know it until we pulled it off (most 4x4 2nd gens are blown according to posts) . The OME unit is 3X bigger than the stock unit and is a huge improvement over stock. You won't notice much difference on the highway (unless you change lanes fast) but offraod it eliminates steering sway over bumps and dips . A great cheap mod to do under $100.
arisegame20
Nov 17, 2010 11:47 AM
LITLRED
May 5, 2010 08:19 PM
yaqui
Feb 2, 2009 04:11 PM
nrgetic99
Dec 7, 2005 06:56 AM
Hyperlite
10
Aug 20, 2003 08:52 AM
