new air intake fried air sensor
Old Jul 21, 2004 | 11:27 AM
armybombtech's Avatar
I recently installed a new air intake on my 2001 Tundra. It was an Ebay special (no instructions), but the installation seemed to go well. One good rev' over 3000rpm, and that was it for the air sensor (positioned into intake tube). I put the stock intake back on, and replaced the sensor. Should I scrap the intake or try again?
The motor is the 4.7 V8. How do you "reset" the computer?
Old Jul 21, 2004 | 11:35 AM
jimbo74's Avatar
did you reset the computer after the intake an allow it to recalibrate itself for the increased airflow?
Old Jul 21, 2004 | 11:37 AM
rimpainter.com's Avatar
Please define or post a picture of this "air sensor."
Old Jul 21, 2004 | 11:42 AM
jimbo74's Avatar
i read it as refering to the maf, and although i have never heard of blowing a maf, i wonder if internally it got shockloaded and tripped out... however, if that were the case, seems like it would be the computer.. not a sensor that went bad, unless he broke the element or somehting during hte install
Old Jul 21, 2004 | 11:43 AM
Yeah that's what I am wondering too. And, he did not mention which motor he has (not like it really matters that much) but it would be nice to know.
Old Jul 21, 2004 | 12:26 PM
I have the 4.7 V8. It's the air sensor that plugs into the intake tube (Hitachi). I didn't "reset" my computer. How do you do that?
Old Jul 21, 2004 | 12:34 PM
How do you know the MAFS was bad - for sure?
Old Jul 21, 2004 | 12:36 PM
jimbo74's Avatar
you disconnect the negative battery lead for half an hour... then wehn you reconnect it, let it ide for awhile then go drive it with varying degrees of throttle
Old Jul 21, 2004 | 12:55 PM
The truck would drive fine up to 3000rpm, so I "limped" it back to the dealer. I played stupid, and they told me that the sensor was bad.
Old Jul 21, 2004 | 03:44 PM
playswithfire's Avatar
Hey Armybombtech:
Don't know what your ebay intake looks like, but I imagine it came with a gauze cone-type air filter. If so, here's what probably happened: the filter had too much oil on it, some of the oil got sucked into the sensor, then the sensor couldn't do its job and the motor ran like crap. People with aftermarket K&N filters have had similiar experiences. The dealer diagnosed it quickly as a bad sensor without bothering to clean it.
If you like the looks, sound or performance or the new intake, I would keep it. Just learn how to clean your sensor (search Yotatech), and you should be able to fix it if it happens again. IMHO only, so good luck.
Old Jul 23, 2004 | 09:35 AM
motorhead99's Avatar
if your check engine light came on you need to flash your PCM if not it may take 2 to 3 cycles.. a couple of days.. for it to reset.
rock on,
matt
Old Jan 6, 2006 | 08:52 PM
lybones's Avatar
I'm having the same problem. Got a obd II reading which shows MAF circuit low input. Cleaned MAF with contact spray cleaner same problem. Truck pulls real strong, but almost cuts at 3000rpm. still investigating.
Old Jan 7, 2006 | 07:20 AM
MTL_4runner's Avatar
There are some cases where cleaning the MAF does not fix the problem and it requires replacement (you can also check with the boneyard for a used one at a reduced price).
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
