need input on 3.0 electric fan
Old Jul 7, 2005 | 06:01 PM
rock star mike's Avatar
i am considering going to electric fan on my 3.0. pros/cons? what's good/ what's junk?
Old Jul 7, 2005 | 06:12 PM
ChickenLover's Avatar
Hey Mike,
If I'm not mistaken, you guys get some pretty hot weather over in San Jose.
I was running a flexalite black magic electric fan ($230). As soon as the temp got to 85* I would overheat. And yes, I'm sure it was the fan. I did a run up a steep windy grade at about 85* and sure as ˟˟˟˟˟ it overheated. I went back home put the clutch fan back on and did the same drive an hour later with not problems at all.
The e-fan freed up some power for sure and I will be putting it back on for the winter months. The flexalite is considered a high end fan, and it doesn't work worth crap. You may want to look into the taurus fan mod (search), it probably moves a hell of a lot more air than the flexalite (although it takes 4 times the power to run it).
Old Jul 7, 2005 | 06:18 PM
Your the second person that has the same problem with the black magic. very unfortunate, it was my first choice.
Old Jul 7, 2005 | 08:30 PM
dragon564's Avatar
I have put flex a lite fans on two runners over here in Japan and never had a single problem with any of them I ordered from performance products.....
Old Jul 8, 2005 | 07:25 AM
94x4's Avatar
Guest
Go with the Taurus fan mod and you'll be happy.
Old Jul 8, 2005 | 07:43 PM
stockrocker's Avatar
one word. AUTOZONE. for about $70, pick up a 16" electic fan.. works great for me! Also: have you guys with the flex-o-lite fan troubles been paying attention to blade-spin orientation? many electrics come set up as pushers, and you need to flip the blades over as well as reverse polarity to make it a puller... just a thought...
Old Jul 8, 2005 | 07:46 PM
rimpainter.com's Avatar
I have ran FLX210's for the past 3 years in a couple different vehicles. No problems. And yes, it gets hot here.
Do the Taurus fan mod. $200+ for fans (what I paid) is rediculous for the gains. The Taurus fan mod is much more economical. Andy (Bamachem) has a pretty trick new variable controller on his. Cool idea, it varies the power to the fans based on need. So it isn't 100% on/off, it is varied depending on temp.
Old Jul 8, 2005 | 08:22 PM
Yota_Pinoy's Avatar
Doesn't get that hot here...What is this tauras fan mod you guys are talking about?
Old Jul 8, 2005 | 08:46 PM
Marc P's Avatar
They are usually found on 94-95 Taurus w/ 3.8l V6
Looks like this..
It has 2 speeds, and fits on the radiator perfectly. I have mine hooked up to an adjustable fan controller. It comes on at 185 degrees, and is also hooked to the a/c compressor so it turns on when the clutch engages.
Old Jul 8, 2005 | 11:32 PM
94x4's Avatar
Guest
Looks like this..
Yeah, that's it , that's what we're talking about rock star mike... Yota_Pinoy, that's the ticket right there.
coleypull15
Nov 3, 2015 07:41 AM
coryc85
Sep 9, 2015 06:24 AM
jjrbus
Jul 27, 2015 11:06 PM
jackiebrownia
Jul 20, 2015 09:02 AM
1996Taco
Jul 20, 2015 12:02 AM
