Need help. Weird noise/buzz
Old Apr 14, 2012 | 06:39 AM
Kblozano's Avatar
Hey guys. So everytime I start my truck or turn the ignition on, a weird noise and vibration comes from the engine bay.
If I turn the key to the on position. Immediately following the 3 beeps there's that noise coming from the engine bay. If your facing the truck from the front with the hood open it's happening in the upper left hand corner of the bay. I just started to notice it. The truck runs perfect and drives fine. But it definitely doesn't seem right. Any ideas??
Also I had a head unit installed right before I started noticing it but I doubt that has anything to do with it. Please help me out with this issue. I've tried searching but so far Ive had no luck
Thank you all
Old Apr 14, 2012 | 05:19 PM
Kblozano's Avatar
Well I pinpointed the noise to the abs control module. It doesn't sound right but there's no dash light.
Should I replace it? Or is There a fix?
Old Apr 16, 2012 | 08:06 PM
skjos's Avatar
What year is your truck/4runner?
If it is a 2001/2002 4runner (I'm not sure what the truck years are), this could explain the noise:
https://www.yotatech.com/forums/f2/b...raking-137820/
...and...
https://www.yotatech.com/forums/f2/2...e-issue-77485/
Old Apr 16, 2012 | 08:16 PM
Kblozano's Avatar
its a 96 and the problem doesnt sound like mine, it only happens once every time the key to the on position immediately after the third beep. i guess its just hard to explain but i appreciate you responding.
Old Apr 16, 2012 | 10:10 PM
RAD4Runner's Avatar
Originally Posted by Kblozano
... i guess its just hard to explain but i appreciate you responding.
A video with audio would help explain it to those who may have experienced same. Got a smartphone you can record a video & sound with?
Old Apr 17, 2012 | 10:55 AM
Kblozano's Avatar
Yes definitely, I'll do that today after work!
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
Shagool22
Sep 28, 2015 07:53 PM
LotOMiles
Sep 14, 2015 11:45 PM
