Need help with stereo system install
Old Feb 11, 2004 | 06:58 PM
Yoter's Avatar
Guest
Originally posted by gapguy
yep. its 1 ohm...that amp is prolly gonna give you close to 100 watts/channel
Old Feb 11, 2004 | 07:00 PM
User 051420's Avatar
Wire up those front speaks to it. I'm sure it will work. Make sure you use a crossover, or you WILL blow those tweets.
Old Feb 11, 2004 | 07:12 PM
runnerof4's Avatar
my personal opinion, i wouldnt wire up your fronts to your amp cause you might starve your sub of power
Old Feb 11, 2004 | 07:15 PM
If you wire that sub in bridged mode, it will be fine. You can't wire it to all 4 chanells anyways. So there would be NO difference.
Old Feb 11, 2004 | 07:18 PM
  #25
Yoter's Avatar
Guest
So like this:
from the deck front channels do my tweets with crossovers
" " rear " " do my rear mids as current
From the amps front channel hook up my front mids
" " rear channel hook up my woofer
correct?
  #26
runnerof4's Avatar
i have never dealt with a 4 channel with one sub, i have dealt with a 4channel with 2 subs, and every other kind of amp style.
Old Feb 11, 2004 | 07:19 PM
  #27
Yoter's Avatar
Guest
woofer being bridged off of two channels = 900 watts. woofer has 1000. safe?
Old Feb 11, 2004 | 07:22 PM
  #28
Yes, its safe.
About your crossover..this is critical..It should have one input and an out for the mids, and an out for the tweets.. Correct?
IF NOT, yes run your tweets off the deck.
Old Feb 11, 2004 | 07:25 PM
  #29
Also..I think you're stuck on the myth that your amp is giving you 450x4....it really isn't.. Frankly, it's a cheap amp, and they overrate their power. Try half of that MAX. I would expect the amp to give your sub ABOUT 400 watts MAX.. and that SUB is probably over-rated as well. No biggie, it should match up.
Old Feb 11, 2004 | 07:27 PM
  #30
Yoter's Avatar
Guest
Yes, its safe.
The amp has an out for the left & right fronts. nothing says tweets. So I will run the tweets off the decks front channels.
Old Feb 11, 2004 | 07:29 PM
  #31
Yoter's Avatar
Guest
Gotta be better than all ive ever been used to. All Ive ever had is decks running woofers being 10s or 12s. And I thought those sounded OK. Guess I might be in for a surprise. Blue
  #32
OK, so you have no external crossover? Am i getting this?
Old Feb 11, 2004 | 07:31 PM
  #33
This should all run great. However, those numbers mean nothing. Yep, You'll be in for a treat!
Old Feb 11, 2004 | 07:44 PM
  #34
Yoter's Avatar
Guest
No crossover yet. where should i get one or however many i need?
Old Feb 11, 2004 | 07:54 PM
  #35
you'll need a pair.. try www.thezeb.com or crutchfield.com
Old Feb 11, 2004 | 08:14 PM
  #36
Yoter's Avatar
Guest
A buddy says crossovers are for technical setups & to just do like he did and use bass blockers. Are they any good? if so which one?
http://www.crutchfield.com/S-7rAQpdS...h=bass+blocker
Old Feb 12, 2004 | 05:23 AM
  #37
Bass Blockers and crossovers are essentially the same. A crossover would save you a lot of wiring, and produce better sound. However, since your speakers didn't come with them, it will be expensive. So Bass Blockers may be your best bet. I'd put them on my speaks and on my tweets.
http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
Run those JUST on your tweets.
Old Feb 12, 2004 | 01:14 PM
  #38
Yoter's Avatar
Guest
Thanks GG you helped me out a lot. I will tell you how it turns out sounding soon. Blue
icentropy
Sep 16, 2020 02:47 PM
coryc85
Sep 9, 2015 06:24 AM
Esibnitsud
Jul 30, 2015 08:21 PM
jjrbus
Jul 19, 2015 02:06 PM
bryan34w
Jul 6, 2015 05:53 PM
