Need help with stereo system install
Old Feb 11, 2004 | 05:42 PM
Yoter's Avatar
Guest
Question Need help with stereo system install
I have my system ready to go but need help with how I should install it. I know how but want some direction so I don't mess it up. Heres what ive got:
*160 watt Pioneer deck
*300 watt tweets
*unk watt front mids
*unk watt rear mids
*1800 watt Xblod amp (LOL)
*1000 watt Xblod 12" woofer (LOL)
*1800 watt amp install kit
So I know this isnt the best set up but its what ive got to work with. Thoughts, ideas, options?
**Concern** I have been wondering how to run my rear 2 channels from the deck. Do I run the left channel to both rear mids and leave the right channel for my woofer? Or is there another way? Help! LOL
Blue
Old Feb 11, 2004 | 06:12 PM
User 051420's Avatar
In theory, you COULD run all 4 regular speaker channels from your deck. However, it would be seriously underpowered. Do you have crossovers for your tweets? If you do, all you have to do is wire one channel to the crossover, and it'll power both the tweets, and mids. I SERIOUSLY DOUBT it will sound anywhere near desireable if you run those speakers off your head unit.
How many pre-out's does your deck have? If it has 3- wire your sub's RCA's to the S/W out on the deck. If it has 2, wire it to the rear outs.
I seriously suggest you get a 4 channel amp to run all of your speakers, It will make all the difference in the world. No joke.
Old Feb 11, 2004 | 06:15 PM
Yoter's Avatar
Guest
OOPS I ferrrrrgot to tell yuh. its a 4 channel
Old Feb 11, 2004 | 06:19 PM
OK..here is what I would do if I HAD to.
Run your front speakers off of the two front channels on the amp. Period.
Run your rear two speakers off of the deck.
Run your subwoofer bridged on the rear 2 channels of the amp if it can handle the power. If not, just use one channel.
MAYBE MAYBE MAYBE you can run both the front and rear speaks off the front channels of the amp. This is entirely the WRONG way to do it, but it might just work.
I'd say get another amp for your sub, and use that xBlod to run the speaks.
best of luck!
Old Feb 11, 2004 | 06:33 PM
Yoter's Avatar
Guest
best of luck!
Wouldnt running an 1800 watt amp with front alpine mids that are an unk wattage & factory rear mids blow them to smitherenes? I got the amp to run my woofer on it.
Old Feb 11, 2004 | 06:36 PM
Do you have the specs on that amp? It's prolly 1800 watts, bridged, at 1 ohm.
Old Feb 11, 2004 | 06:37 PM
For sure, run the factory rears off the deck. And if the amp is small enough, run the fronts on it.
Old Feb 11, 2004 | 06:39 PM
runnerof4's Avatar
what i would do is just run your front and rears speakers off deck power and pound the crap out of your sub with your amp. this is what i did for my very first system and it sounded good.
Old Feb 11, 2004 | 06:40 PM
Yoter's Avatar
Guest
this amp is a big honkin thing. 450 per channel. pretty sure my front mids are not 450
Old Feb 11, 2004 | 06:42 PM
Yoter's Avatar
Guest
i think i get where my logics are wrong. I can run the tweets & front/rear mids off of the deck. Do the RCA's count as more channels from the deck?
Old Feb 11, 2004 | 06:46 PM
your tweets/front mids should count as only 2 channels. If you have a crossover, which you should. I can promise you that your deck doesn't put enough power into those mids (22watts rms).
I'm sure your amp is rated at those 450 watts at 1 ohm..maybe 2
Old Feb 11, 2004 | 06:47 PM
runnerof4's Avatar
you use the rca's to run sound to your amp
Old Feb 11, 2004 | 06:49 PM
Yoter's Avatar
Guest
My thinking is ticking like this: If you have a power source (AMP) with 450 watts going into sat 150 watt mid range speakers it will blow them. Is that wrong to think that way?
It's probably safe to say that your amp is grossly over-rated and it is indeed safe to run your fronts on it.
Old Feb 11, 2004 | 06:50 PM
Let me see the link to the auction of your subs again..I wanna investiate the actual power.
Yoter's Avatar
Guest
bingo. gotcha now. god im effen stupid. thanks so much
Old Feb 11, 2004 | 06:52 PM
runnerof4's Avatar
it wouldnt blow them, because the 450 watts on your amp is it full power, for example when you have the volume turned all the way up
Old Feb 11, 2004 | 06:53 PM
full power at a likely 1 ohm, rather than 4.. generic amps are almost always over-rated grossly
Old Feb 11, 2004 | 06:54 PM
Yoter's Avatar
Guest
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
Old Feb 11, 2004 | 06:56 PM
yep. its 1 ohm...that amp is prolly gonna give you close to 100 watts/channel
