need help with a chirping noise - 97 4runner
Old May 29, 2004 | 04:06 PM
sage's Avatar
Lightbulb *UPDATE on fix...need help with a chirping noise - 97 4runner
Hello all,
Need help with possible diagnoses before I go to the mechanic. My 97 4runner (4 wheel drive) has developed a noise that sounds kind of like a cricket. When I depress my clutch, it goes away. When I let it out in gear, it returns. When I start moving from a complete stop, the sound gets faster. It does not seem to be coming from any of the belts or the fan. Any thoughts? Does this have anything to do with the throttle body?
TIA
As noted above, I went to the mechanic and my clutch and bearings were damaged. I had my clutch assembly and bearings replaced as well as the flywheel remachined. The 4Runner shifts better than I ever remember it!
All work was done at Protrux in San Marcos (SoCal) for a grand total of 551.00
Thanks for everyone's help.
Old May 29, 2004 | 04:48 PM
Scofco's Avatar
There's your hint right there.
I have the same thing, it's the throwout bearing on my truck.
Doesn't cause any damage to the truck, just to your brain from it driving you CRAZY!
Old May 29, 2004 | 04:56 PM
Maddog's Avatar
off topic,
Scofco ,i love the colour of your runner,havent seen many that flavour.
Old May 29, 2004 | 05:01 PM
AznSky's Avatar
ok this might be a stupid suggestion, but could it be a rock in between your tires? Cuz that makes a chirping sound as well lol
Old May 29, 2004 | 10:16 PM
sage's Avatar
Thanks Scofco, What does the throw out bearing actually do? It is definitely driving me nuts!
Old May 30, 2004 | 05:30 AM
HondaTec521's Avatar
It's more likely a mainshaft bearing .When you push in the clutch the throwout bearing is pushed against the pressure plate and starts spining and if it was worn thats when it would make noise .With the clutch not depressed at idle in nuetral the mainsahft is spinning at engine RPM,and the throwout brg. is not moving.Check your transmission oil level ,it might be low.But it looks like you might be needing some trans. work. :
Old May 30, 2004 | 05:43 AM
Jonathan's Avatar
Mine makes the same noise if that makes you feel any better. I also just had my clutched replaced less than a year ago and the noise is back already. I think I'm going to have to go to Toyota and see what's up, because it's driving me insane. Not to mention I have a heat shield rattle that I still have not pinpointed
Old May 30, 2004 | 07:55 AM
Scofco's Avatar
Originally Posted by Maddog
off topic,
Thanks mate
Old May 30, 2004 | 08:14 AM
Bob_98SR5's Avatar
Guys,
I had the crickets and the cure was to change out the manual tranny fluid. If you are going to do that, I highly recommend (i mean HIGHLY) Redline MT-90. Do a search and see my as well as other people's threads on the subject.
Bob
Old May 30, 2004 | 01:36 PM
Jonathan's Avatar
Originally Posted by Bob_98SR5
Guys,
Bob
Thanks Bob, I'll look into that and see what comes of it. Let me know if you have any other suggestions.
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
Poncho0206
Jul 10, 2015 06:21 PM
