Need help with 90 22re
Old Aug 28, 2004 | 09:50 AM
10cents's Avatar
I have a pickup with the 22re, when I start it up it idles for a few minutes then starts turning off. It will run for about 2 minutes before it cuts off. When I push the gas down about 1/4 of an inch it will rev then drop like its hitting a rev limiter but its only at like 1-2k (no tach). If I push it down any more it will rev up just fine. Once it gets warmed up (about 10-15 mins of driving) it will idle fine most of the time but still cut off occasionally. I replaced my spark plugs and checked the PCV to make sure it had good vaccum and it was fine. Im thinking it might be some kind of air flow sensor or something? Any help would be greatly appreciated.
Oh, I checked the vaccum lines to the cylinders (whatever those 4 lines in my intake are) and there is only supposed to be vaccum in line A at idle (according to Hanes manual) but the Vaccum was in the line next to A not A.
Old Aug 28, 2004 | 10:37 AM
88yotaboy's Avatar
Check the timing and the idle speed.
Old Aug 28, 2004 | 10:41 AM
colsoncj's Avatar
How long has it done it? Is the truck throwing a check engine code?
Old Aug 28, 2004 | 10:52 AM
SoCal4Running's Avatar
How many miles are on the truck?
Old Aug 28, 2004 | 12:06 PM
10cents's Avatar
Its got 143k on it. Its been doing it for about 3 days since I got it back from the shop. The mechanic that was working on it said "I couldnt find anything wrong with it." I just went to the land fill and it got really bad on the way home, cutting off constantly at idle and it is jumping really bad if im not at WOT. Its not giving me any code. I turned the idle screw thing about half of a turn and it didnt help so I turned it back.
Old Aug 28, 2004 | 12:53 PM
Check all your wiring connections, including all injectors. Definatly sounds like something is partly unplugged.
Old Aug 28, 2004 | 01:00 PM
ebtide's Avatar
Sounds like the throttle position sensor to me. Good luck.
Old Aug 28, 2004 | 02:36 PM
Thats what I was thinking to but wouldnt that turn on the CE light.
Old Aug 28, 2004 | 03:09 PM
PirateFins's Avatar
cap, rotor, fuel filter, spark plug wires, tps, egr, dirty TB with clogged vac ports.
These are somethings to check.
Old Aug 28, 2004 | 03:26 PM
10cents's Avatar
Ok, I cleaned the TB but it didnt help. I cant start the motor without it stalling now. If I dont floor the gas it will not stay running.
Old Aug 30, 2004 | 04:38 PM
Thats gotta be your TPS, either not adjusted properly or just whacked.
Old Aug 30, 2004 | 11:07 PM
colsoncj's Avatar
My TPS was outta wack, and it didn't throw a check engine code. However when i did check the codes it pulled up a code that the idle position on the TPS wasn't set properly. I would look into the TPS...
JNapolitano
Nov 14, 2019 07:46 PM
Stull
Aug 28, 2015 05:53 AM
ia02
Aug 20, 2015 11:04 AM
PlayAwhile
Jul 20, 2015 11:36 AM
