Mysterious black box
I was under my truck trying to find the reason that some smelly red fluid is leaking and discoverd this wierd black box bolted to my transfer case. It has no wires going to it and is not shown in the Haynes repair manual anywhere. It is bolted on to a 3/8" thick PL bracket with reinforcement on the backside. It could take a serious blow and not get knocked off. The bracket is bolted to the transfer case using two of the existing bolts on the transfer case. The only thing I can come up with is that it is some sort of tracking devise used by aliens :alien: wating to find the opertune time to probe me
. So I switched cars with my wife untill I could poll you guys for an idea as to what it is. Any ideas?
OK, it's either one of two things... might be Lo Jack
Or the Mafia has found you after your years of hiding in the witness protection program!!! Lock the doors and grab your ammo!
You might take it to the dealer and let the device explode there
They need a wake up call!
Originally posted by mpulver
It's a harmonic balancer. It's there to help recuce sympathetic vibrations coming from the transfer case.
It's does much the same job as the balancing weights on your wheels.
I guess I will leave it alone then. Do all Runners have these?
Originally posted by TRunner
That doesn't do my wife any good then....
Do a search on "harmonic balancer" for a bit more background.
Mark
Originally Posted by 4RunnerKid
bringing back an old thread, i know... do you guys know if these can be removed without serious vibration? or are they pretty essential?
Well the factory would not put it on to save money in the first place if it wasn't important so I would just leave it on.
yeah, it definitely is...
so, anyways... can i possibly move it farther up? would that even be an option? i'm only asking because that damn thing hogs ground clearance... and i always manage to hit it when i come down on rocks...
i have a 93 runner also, you shouldnt be hitting that box as your tcase crossmember and skid should be taking all the impact. you may want to look at doing a drive line lift if you are having clearance problems. 4crawler has a pretty good write-up on that mod.
lee
lee
i would love to do a drivetrain lift, but without a body lift i'm limited to an inch or two... doesn't even seem worth it... i might still do it eventually. i just need to protect the t-case for now. i'm actually getting this skid done sunday, so i'll post pics for you guys.
yay for old thread revivals. ok so on the weekend while doing a pretty gnarly trail, it looks like i did some major damage to this 'box' (among other things
. just for clarification, its the one thats shaped like a half a hexagon or something? anyways..its umm..quite bentup now. the bracket holding it up has folded up quite a bit. i havent noticed any vibrations during driving. maaybe a slight whir i noticied on the drive home, but i dont notice it anymore. im guessing a replacement is in order..but for the time being, is it detrimental in any way to my driveline? enough that if i cant get to it ASAP..worse things will happen?
at least ive got that much more clearance now!
. just for clarification, its the one thats shaped like a half a hexagon or something? anyways..its umm..quite bentup now. the bracket holding it up has folded up quite a bit. i havent noticed any vibrations during driving. maaybe a slight whir i noticied on the drive home, but i dont notice it anymore. im guessing a replacement is in order..but for the time being, is it detrimental in any way to my driveline? enough that if i cant get to it ASAP..worse things will happen?at least ive got that much more clearance now!
:alien:
