My "Newest" HID Project...
It's been awhile since I have had a chance to post about my newest HID project. You may or may not know about my HID Hella fogs I installed awhile back...but they are performing excellent. I upgraded my headlights to the following:
Acura TL Bi-Xenon HID Projector Headlights w/BMW ZKW Clear Lenses and Angel Eyes "Halo" Lights and Philips DL50 50 watt (5300 lumens) HID Bulbs w/Retro Solutions 55 watt DIGITAL Ballasts.
It's "daylight" with no glare. The Halos are wired to my corner lights so I can run them with or without the headlights. Here are some pics:
With Halos installed, but before Halo shroud:
With Halo shroud:
This is what I used from Home Depot for my Halo shroud:
Finished project:
Just Halos:
Halos & HIDs (Glare is from camera):
With Halo shroud:
Finished project:
Just Halos:
Looks awesome, make sure your cutoff point on the HID's isn't too high that it's blinding everyone at night. I hate people that do that.
Edit: How strange, Beyonce's song "Halo" just started playing in my roommates room.
how is it with 55w ballasts? I have a very similar setup; TL-projectors, ZKW lens, philips bulbs, and hella 35w ballasts. I keep contemplating if the more powerful ballast would be worth it to try out.
This thread should help:
https://www.yotatech.com/forums/f2/h...w-pics-133563/
Go to Home Depot and purchase (8) about 2" long bolts with (3) nuts and washers per bolt. Line up the holes in the projector with the reflector and mark where you will need to drill a hole for the bolts to fit through. Be sure to clear silicone the rear of the projector to the housing and where the bolts come through. The pics in the above thread should help.
You should have the projectors as level as possible in the reflector housing before sealing the glass back on. Then you can do final aiming adjustment with the original housing adjustment nuts.
you would have to do it yourself. It's probably not a good idea to pay someone to do it unless they are doing it on your truck on the spot. For instance, if you paid someone across the country to make one for you and aligned from their truck. Then you receive it in the mail and mount it up on your ride.... the alignments could be way off only because the heights difference on both vehicles.
side note, look for my thread my project too. I will finish the write up tomorrow.
Dang.... super clean job..
To clean it up even more have you thought about some led's for the markers? It would flow more into the halos and HID's I mean color wise. But either way very nice.
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
clok
Nov 19, 2015 01:09 PM
