My Bad Yukon Gears
Old Mar 31, 2005 | 06:24 PM
  #121
dragr1's Avatar
Originally Posted by AznSky
just the ones on the diff housing.
And dragr, as for your mileage, I think you should be reading the 14% one. Because I had my mom in her rental car drive the same exact distance I did for over 50 miles, and my odo was off by 13%. So add the 13% and I get around 16 mpg city. Factor in your roof rack and spare will drop it by 1 mpg, and you're gettin 15. Sounds fair
Cool, that's what I thought, but wasn't sure after Andy brought up the other way.
Old Apr 1, 2005 | 03:53 AM
  #122
bamachem's Avatar
Cool...
So, with that info on the distance traveled, then the ODO is also based on the ABS system at the axle and not in the XF case...
I'll update that thread...
Old Apr 1, 2005 | 04:36 AM
  #123
ZUK's Avatar
ZUK
dragr1---I'd like to see you try the acetone in the gastank thing....might improve your mileage 30%......no more than 4oz(1/2 cup) to your tankful.
Old Apr 1, 2005 | 04:56 AM
  #124
bamachem's Avatar
yeah, ZUK... i saw that on pirate too.
i tried it. it gave me a ~2mpg increase (from about 17.5 up to 19.5 on the highway) on the first tank, then i ran two tanks w/o any and the mpg dropped back down. i'm now running it again in this tank to see if the mpg's go back up.
i'm running 3 oz in a ~15 gal fillup.
i still think brett has a sick O2 sensor causing his bad mileage. i had one (front sensor) that wasn't throwing codes but was killing my mileage. i replaced it and went from 15 MPG to 17.5 on the very next tank.
Old Apr 1, 2005 | 05:18 AM
  #125
sschaefer3's Avatar
Originally Posted by bamachem
Cool...
I don't know about that, I added the gizmo only to the t-case sender and now I have completely removed the ABS and it's all still working. I had the same ABS computers etc. as the rest of you guys.
Old Apr 1, 2005 | 05:30 AM
  #126
bamachem's Avatar
hmmm....
Old Apr 1, 2005 | 07:23 AM
  #127
dragr1's Avatar
Hmm again, now I'm really confused. I think I have an 02 sensor from a junkyard 4Runner. I may swap it and see if anything happens. I would like to know how bad the odo is off though.
Old Apr 1, 2005 | 08:12 AM
  #128
AznSky's Avatar
didn't you say you used a gps? That should be pretty dead on
Old Apr 1, 2005 | 09:22 AM
  #129
dragr1's Avatar
Yes, I used the GPS. I even logged it over several miles and at different speeds. Andy and Steve are saying that the odometer doesn't read from the same source as the speedo, so it may read differently. Andy has a valid point and his theory is mathematically correct, I just want to know which one works. Edit: I only checked the speed with the gps, I guess I should check the mileage (distance traveled) too. Maybe I can do that Sunday or Monday, I'm leaving in the Chevy this afternoon to go camping.
Old Apr 10, 2005 | 10:58 AM
  #130
dragr1's Avatar
Latest update. I'm over 500 miles now and will change the gear lube this week. I checked the odometer versus my GPS this weekend. I logged it over a 100 mile trip. Here is what I got:
GPS 100 miles
4Runner odo indicated 84.7 miles
So that is 15.3% off for the odometer, but I'm still only calculating the speedo to be about 14% off.
Given the 15.3% off, I averaged 15.7 mpg going about 70 mph on hilly terrain (not mountains) with the a/c on. When I filled up, the fuel gauge was at about 1/2 tank, but I could only squeeze in 6.95 gallons.
The power with the 4.88's was nice though, on some big hills where I would previously lose 10 to 12 mph in 5th gear, now I only lose 3 or 4 mph.
I'm thinking I have some problems here though. I know I'm probably losing 1 mpg to the tire on the roof-only place it will fit for now. Also, my 4Runner through the P0171 code a weeke ago, autozone cleared the code and it has not come back yet. So, maybe the front 02 sensor needs replacing?
I have also heard some talk of a TSB on fuel gauges? I'll be doing a search for info on that today, b/c isn't the fuel tank 18.5 gallons? If so, I shouldn't be reading 1/2 full when I've only used 6.9 gallons-the pump clicked off at 6.1 gallons, but I squeezed in the extra.
Old Apr 10, 2005 | 11:02 AM
  #131
terryjmatthew's Avatar
I thought our fuel tanks were 16.5 gal, but I may be wrong.
I also talked to Dyas Toyota about TSB's and they said there were none.(assuming they were telling the truth)
-Matthew
**edit**
I am averaging 17.5 combined MPG w/ my 265's.
Old Apr 10, 2005 | 05:48 PM
  #132
AznSky's Avatar
sweet. So it IS off. Excellent, that means my mileage is A LOT better than I thought it was.
on a side note: I drove a Matrix this weekend down to Purdue from Michigan, over a 600 mile trek. Only had to fill up twice with 34 mpg!!!!! I seriously need to switch cars..........
Old Apr 10, 2005 | 06:58 PM
  #133
dragr1's Avatar
Yeah, I'll be looking at one of those or a Corolla S for the wife in a few months.
What do you estimate mpg wise on your 4Runner now?
Old Apr 11, 2005 | 03:11 AM
  #134
AznSky's Avatar
around 16.5 mpg city driving with only a 13% correction.
I'll find out highway this weekend when I make the same trip with my 4runner
Old Apr 15, 2005 | 06:04 PM
  #135
dragr1's Avatar
Got the brake controller and the 7 wire harness all hooked up and the gear oil changed. Tomorrow is the maiden towing voyage! I'll post how it goes.
Old Apr 16, 2005 | 03:37 PM
  #136
dragr1's Avatar
Finally got to tow it today after a lot of running around. I went out and towed it 12 miles and right now I'm letting it cool off before doing it again and then maybe 2 more times tomorrow to get the correct towing break in miles done.
Anyway, it towed fine. I didn't get in a big hurry-not that I could. For a refresher the camper weighs about 3600 to 3700 pounds with a tongue weight around 350 to 400 pounds. The sway controller really helped on the interstate and the wind (about 15 mph) today. Also, the Prodigy brake controller I installed works great. I got up to about 75 mph on the interstate briefly, I think towing this camper is gonna be best around a top speed of 65 mph. I can tow in 5th gear on flat ground, but 4th is a must for any hill at all. Really long or steep hills may require 3rd-I'm sure everyone behind me is gonna hate me in the mountains.
I had no problems with the rear bumper that I have been concerned so about, and the movement that I was feeling through it seems to be gone or way less than it was. Now, I need to go to Wal Mart and buy some mirrors for towing b/c all I see behind me is camper.
Old Apr 18, 2005 | 10:26 AM
  #137
I know what you mean about towing. Just made a quick run to Auburn and towed back a 6x12 Uhaul (loaded down). With my A/T I had to keep it in 3RD gear to stay above 65mph. Ended up averaging 13.5 MPG over the 700 mile drive...
Old Apr 26, 2005 | 10:48 AM
  #138
sschaefer3's Avatar
I have my rear axle off the truck and completely torn apart. In 2002 the Yukon gears I got were indeed made by US Gear, my ring has the Interstate sign with the G in it.
They still look good, 45K later. More milage than I had on the stock gears.
Old Apr 26, 2005 | 12:16 PM
  #139
dragr1's Avatar
Out of curiosity, whatcha doing to the axle?
Old Apr 26, 2005 | 05:00 PM
  #140
RTdawgs's Avatar
First time reading this, any updates from anyone?
Im considering re-gearing. My 4R is so damn heavy and i believe its killing my power and gas mileage, even with the Supercharger. I have 265s now, but would love to get back to 33s next time, hopefully 305s. 4.56 v. 4.88 ????? Such a dilema, but plenty of time to make the right decision.
