MOD question: why bleed the brakes?
I was just reading over the tech for coil and shock installation on a second Gen and i was wondering why after everything was installed did uk meyers then bleed the breaks. I'd like to be doing the mod soon and know everything i can in advance. thanks
Good responses guys 95 Toy the Downey set up comes with a longer stainless line that goes to the proportioning valve. When you disconnect the old one air can and will get into the line. Once done bleed in this order Right Or left wheel doesn't matter but bleed both wheels and then the proportioning valve. Good luck with the mod. BTW the longer brake line is really not needed but it's good to have. I know a guy with the coils and the spacer kit using the stock line but he is at risk of ripping the line off if he ever does a really radical flex...(is that possible on a stock set up).,.haha
Originally posted by UKMyers
.... I know a guy with the coils and the spacer kit using the stock line but he is at risk of ripping the line off if he ever does a really radical flex...(is that possible on a stock set up).,.haha
Downeys' instructions mention flattening the seam on the gas tank skid plate to avoid hitting. When I am at full flex in the rear there's about 1/8" of clearance before I hit still and I never changed anything back there on the skid plate
Originally posted by 92 Toyota
Is it true that when you bleed a brake system you start from the farthest point from the master cylinder & work closer?(e.g.back right 1,back left 2,front right 3,front left 4)
id recommend getting some more clearance just for good measure, dunno if that hurt my driveshaft or not. only time will tell
bleeding the brakes is no big deal, takes like 3 min with a buddy to help you
Originally posted by NCSU-4runner
do you disconnect your rear swaybar?
priest16
15
Aug 6, 2015 07:43 AM
