manual transmission question
Old Aug 1, 2016 | 03:00 PM
bowhunter1640's Avatar
hello I have a 96 Tacoma that I just put a new clutch in and while reinstalling the transmission I lost some gear oil so while I have the shifter off still I was wondering if I can top it off through where the shifter bolts to the top of the transmission. thank you
Old Aug 1, 2016 | 03:56 PM
Marc's Avatar
Yes you can. Just don't put too much in.
Old Aug 1, 2016 | 04:11 PM
thank you very much
Old Aug 1, 2016 | 05:01 PM
now if I wanted to change the gear oil in it ( I don't know if it's ever been changed ) what would I use to flush it clean?
Old Aug 1, 2016 | 05:09 PM
millball's Avatar
Diesel fuel would work well.
Old Aug 8, 2016 | 01:47 PM
can I do the same thing with the transfer case? flush and fill it through the shifter? thank you
Old Aug 8, 2016 | 02:17 PM
Marc's Avatar
If when you drained them the old oil still looked good I wouldn't bother with a flush.
Old Aug 8, 2016 | 02:33 PM
haven't drained the transfer yet but already flushing the tranny. the main thing I was trying to make sure of is that I can fill it through the shift selector on the transfer case. thank you
Old Aug 8, 2016 | 04:55 PM
Marc's Avatar
How will you get all the diesel remnants out of it?
Old Aug 8, 2016 | 05:17 PM
I figured I would let it drip until it stopped and then add the gear oil. there should be enough after it stops dripping to matter I would think
Old Aug 8, 2016 | 06:25 PM
millball's Avatar
Any small amount of diesel that won't drain out is irrelevant.
Won't hurt anything.
You should be able to fill the t-case from the top, just like the tranny, provided that it is a TOP-SHIFT case, and not a FORWARD-SHIFT case.
I do not know what tranny and t-case that your year and model truck has.
Old Aug 8, 2016 | 11:54 PM
wyoming9's Avatar
Not sure why you would want to fill from the top .
I would just as soon not have the mess in the cab
I always get the gear oil warm before changing .
Me being a klutz I would never get the smell of Fuel oil out of the vehicle ..
scott.475
24
Jan 7, 2018 08:56 AM
Old83@pincher
Mar 23, 2016 12:39 PM
MudWaspSR5
Mar 8, 2016 03:11 PM
Blissard
Mar 3, 2016 09:17 PM
kdeking
9
Nov 24, 2002 03:57 AM
