Maf code
Old Oct 31, 2017 | 11:15 AM
Dustin1975's Avatar
Maf code
Hello all I have a 1996 2.7 4wd giving me problems. I had advance hook up to a computer and got 3 maf codes. Sorry don t have numbers. When I start it it will die if I don't give it gas. After 20 or 30 seconds it will idle. When I start to drive it starts to die as soon as I hit the gas. If I give it more it will continue running but if not it will die. Also struggles driving. No power and have to feather the pedal to get acceleration. Any help would be greatly appreciated. Thanks
Old Oct 31, 2017 | 01:04 PM
wyoming9's Avatar
Red face
To bad you failed to save your results .
It would point you in the correct direction .
Without knowing your just guessing
Old Dec 16, 2017 | 07:31 AM
Noil's Avatar
Without codes hard to say what's going on. Would start with getting the codes read again and making a note of them. Also probably would try cleaning the MAF and see if that helps.
Djea3
Oct 4, 2017 08:45 AM
myotherrideisayoshi
Jun 12, 2017 09:04 PM
teciwelder
May 24, 2017 05:56 PM
Tilikum102602
93-98 T100s (Build-Up Section)
May 24, 2017 10:01 AM
Randybon
May 13, 2017 10:53 AM
