Lowering Spare Tire with Body lift...
Old Jun 17, 2005 | 10:10 AM
MTNTOY's Avatar
I have a 1" RB body lift on my 3rd gen 4Runner and now I am unable to lower my spare tire! The crank won't go into the spot to lower the tire down.
How do I fix this? Help please...
Old Jun 17, 2005 | 10:14 AM
bob200587's Avatar
take the bumper off.....see if it goes in then. and be sure to put some lubricant on it, cause it can be hard to turn.
Old Jun 17, 2005 | 10:17 AM
bob200587's Avatar
the mechanism could be turned from underneath if you could get something with a large flat tip that is kinda short......might be hard to turn tho. the jack handle gives you a much better grip.
Old Jun 17, 2005 | 10:21 AM
jimbo74's Avatar
drill a new holein the bumper for the arm..... then you wont need to screw with it next time either
Old Jun 17, 2005 | 11:03 AM
Crux's Avatar
Yeah, pull up the plastic bumper part- you should be able to feed the rod through that gap into the lowering hole.
Old Jun 17, 2005 | 11:28 AM
FilthyRich's Avatar
that is ALL you have to do for a 1" BL
Old Aug 4, 2005 | 06:59 AM
Noel's Avatar
im having the same problem. did anyone find a solution?
Old Aug 4, 2005 | 07:04 AM
bamachem's Avatar
put the rod int he hole, tap on the handle w/ the tire iron and it will slip right in. just yank it and it will come right out. very easy w/ no modifications needed and no pulling plastic.
Old Aug 4, 2005 | 07:14 AM
4Crawler's Avatar
All covered in the instructions:
http://www.4crawler.com/4x4/ForSale/...areTireCarrier
Old Aug 4, 2005 | 07:15 AM
hillbilly's Avatar
You can do one of two things:
  1. Remove the rear bumper valance (plastic cover) to access the spare tire carrier.
    OR
  2. Change the angle of the rear tire carrier.
EDIT:Here's a link to a thread I posted awhile ago on how to change the carrier angle.
EDIT²:The link (and text) in Roger's instructions reference the thread posted above.
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
DrZero
18
Jul 24, 2015 11:31 PM
DrZero
Jul 13, 2015 09:59 AM
skoti89
Jul 8, 2015 12:05 AM
