Low-end power loss or just plain SLOW?
Old Apr 11, 2006 | 02:20 PM
midiwall's Avatar
Originally Posted by 4RUNN!N
What I mean't by being expensive and being short on money for was ALL the maintainence work. I guess it threw everybody off when I said not being able to afford it. Just this one time I make a mistake, I get bashed, I guess I deserved it by not wording right.
Sounds expensive, I would do that, but I'm short on money.
I dunno... sounds like you didn't want to do much.
No matter... If you need to assign priorities, then do the major fluids. If you can't do them all (as I listed above) then skip the radiator flush - that'll save you $70. But DO the oil change, oil filter & tranny flush (not a "change") as a must. PS is a "should do", radiator "can wait".
Once you get home - The air filter is a must, fuel filter is a must, clean the MAF & TB - must. Seafoam - must.
Plugs & wires & O2 will be the next thing we tell you if you still have issues after all the above (and you probably will).
So options from the original list... Radiator, PS, plugs, wires & O2. Know though that the Seafoam session could foul your plugs and O2 so you might be "forced" into those. But considering all the crap that's probably on your valves and pistons, I think an overnight Seafoam soak is a must.
Sleaker
Aug 26, 2020 06:03 AM
tj884Rdlx
Aug 28, 2015 12:04 PM
Tacoma1313
Aug 17, 2015 05:44 PM
91yotapup
Jul 27, 2015 07:19 AM
gmonnie123
Jul 26, 2015 02:44 PM
