looking at an 85, but it runs rich
Old Jan 19, 2004 | 02:31 PM
rowan's Avatar
not my truck (edit: YET), but something i might go look at soon. its about 3 hours away, so i havnt been able to scout it out yet. 85 truck 4x4 with a 4" lift and 33x12.50s. the guy says the body has some rust but the frame is ok. asking $500. it needs a new brake master cylinder but he is including a 87 2wd for parts, and he says i can get it off that. the only other problem he mentioned was that it runs a little rich and he doesn't know why... so anyone know how to fix that problem? does it even need to be fixed?
... how easy would it be to change it from carborated over to EFI?
ill try and take some pics when i look at it. seems like a good deal, two trucks for 500 bucks. the 85 just needs a little work and it would be a great trail rig.
thanks in advance for replies.
Old Jan 19, 2004 | 06:10 PM
Todd E's Avatar
If it runs rich only during warmup, then it's probably the AAP diaphram.
Easy to replace, about $40 at dealer.
You could rebuild the brake master cyl in the 4x4 and have both trucks to drive cheep!
I say pick them both up. Should be fun
Todd
Old Jan 19, 2004 | 07:30 PM
tenfourtyeight's Avatar
Why can't I find deals like this?
:beaver:
Old Jan 19, 2004 | 07:57 PM
rowan's Avatar
Todd - he said it runs good when its cold out, but once it gets warm it runs rich.
I think I can swap brake cylinders, but I'm not sure about rebuilding one. btw, the 87 does not run. not sure what it needs though.
Im not sure how much of a deal it is yet. It could be a P.O.S..
...got any more feedback on the running rich problem? anyone?
Old Jan 20, 2004 | 06:43 AM
Todd E's Avatar
I'd look for vacuum leaks probably.
Either that or EGR/smog pump issues. I'm about to finish disabling my "smog pump". Just have to wait until this weekend so I have some time to do it.
Or, make it easy on yourself and swap in a Weber carb. (need a fuel pressure regulator though).
Not sure if there's a difference in the brake master cyl's or not. I don't think so, but you could check part numbers/etc. to be sure.
Would be interesting to konw why the 2wd isn't running.
Todd
Old Jan 20, 2004 | 11:43 AM
rowan's Avatar
well nevermind. i guess it has been sold. :cry: :cry: :cry: :cry: :cry:
what a bummer, seemed like a killer deal. but i dont really know since i never saw the truck. somethin else will come along. just got to go with the flow, right? must not have been the right truck for me.
but until then.. :cry: :cry:
Old Jan 20, 2004 | 04:23 PM
StoryR's Avatar
Hell, for a deal liek that, you would not only get two trucks, but a SFA, and a 4" lift kit...seems like those alone are worth more than $500.
Sorry you didn't get it
Old Jan 20, 2004 | 07:25 PM
Albuquerque Jim's Avatar
85 4Runner
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
coffey50
Jul 28, 2015 10:55 AM
calderp
Jul 27, 2015 09:58 AM
