LOOK what i got today!!!!!!!!
Originally posted by mertztr
Oooooh.......Ahhhhhhh.......
How much do you expect install to run you?
what would you expect to pay?
u think i should try and do it myself? i know Jeff Mosk over on ODW has a write up. the only problem im worried about is i have to weld the collector to the cat because the cats on 4runners dont have a flange, the pipe just goes straight into the cat.
-Casey
Sweet!
I'm jealous. You should send in a sound sample to the Exhaust page that Corey has. There are no 4cylinders on there! Do you have the rest of your exhaust opened up? Also, keep us informed on performance gains.
Originally posted by Plays_with_Toys
Sweet!
Sweet!
i will keep you guys informed on performance gains as i hope to see something!
-Casey
hey casey, if i were you I would have the cat cut off from the down pipe and have an exhaust shop weld on a flange to the cat. That way if you wanted to put in a high flow cat or even remove the header it is not attached. I am probably going to get the LCE header also. www.sdtrux.com is going to do my install. If you cant find a good shop they might be worth your hour and a half drive.
-Casey
Well when i first bought my truck it had the cracked manifold. I just replaced the manifold, DOH i am kicking myself for not getting the header, and they charged me $150 for the install. So i think they would charge the same, probably more if you are going to have them modify the downpipe.
Steven.m.paulk
Jun 7, 2020 10:45 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
PNW94Runner
Sep 29, 2015 02:55 PM
