Lift Kit Help
Old Jan 13, 2003 | 06:34 PM
fooddude's Avatar
Post Lift Kit Help
Hi my name is Kyle. I just got a 4runner for my Sixteenth birthday, and i was wanting to put a 3 inch body lift kit on it. Does anyone have any info on it. Like is it easy to install. Thnx
Old Jan 13, 2003 | 06:36 PM
RTdawgs's Avatar
what year and tranny?
Old Jan 13, 2003 | 06:45 PM
fooddude's Avatar
its a 94 five speed. Also will 33s fit in there
Old Jan 13, 2003 | 07:20 PM
RTdawgs's Avatar
33x1250s will fit with the proper wheel on a 3" body lift.
my suggestion: dont get a 3" body lift. save for the PC or Superlift kit or get some rear coils and new t-bars and get a 1 or 2" body lift.
install will be a pain, gotta extend just about everything. expect it to be a weekend project.
Old Jan 13, 2003 | 08:51 PM
sleepy1405's Avatar
speaking of lift, how would I got about lifting my 02 4runner just a couple inches? Should I wait awhile, what things to I have to replace?
Old Jan 15, 2003 | 06:58 PM
fooddude's Avatar
what type of lift and what size
Old Jan 15, 2003 | 07:28 PM
Skydigger's Avatar
Most 2nd genners get the Downey HD rear springs and crank the Torsion bars a bit. You'll need the full 3" rear suspension lift which includes the spacer to fit 33s. You might also have to do some fender trimming in the front after you crank the T-bars to fit the 33s. Don't crank the T-bars until you get some manual hubs installed to reduce wear on your CVs.
If you wanna go to 33s x 12.5" tires you'll be needing some non-stock 8" wide rims. Once those are on your speedo and odometer will be off and you may notice a real change in power from your engine. If this is the case, look into re-gearing your differentials to a 4.88 or 5.29 ratio.
33" tires are the point where you really have to jump through hoops to make it work. I'm sure you can see how one thing leads to another.
My suggestion to you if you wanna save some time and money would be to get the Downey HD coils, some AISIN hubs from a wrecker, crank your T-bars a little and put some 32 x 11.5 tires on your stock 7" rims. This would be a good start and then go wheeling.
Also, search this site and the internet for info as there's plenty out there for the above topics. You should have no problems doing it all yourself.
Good luck,
Warren
Old Jan 15, 2003 | 07:35 PM
Corey's Avatar
Co-Founder/Administrator
Kyle, see this post.
If you want to run 33" tires on a 2nd gen 4Runner, a 1" body lift from 4Crawler, a crank on the T bars, and Downey HD coils in the back with their 1.5" spacer add on will let you run 33's with ease.
Putting on a big body lift like you are thinking of is nothing but trouble.
You'd have to fab up new front bumper mounts, extend your shifters, radiator.
With a 1" body lift, you don't have to do that.
Your rig will sit like the black truck basicaly if you do that, and be able to fit 33" tires.
You will also save a lot of money over an IFS lift kit to achive the same thing just to fit 33" tires on.
But, going to a 33" tire is also going to effect your stock gearing.
PS, Warren, we were thinking the same thing at the same time :eek:
Old Jan 15, 2003 | 07:40 PM
Skydigger's Avatar
Old Jan 15, 2003 | 09:32 PM
sleepy1405's Avatar
what type of lift's are there?which one should I consider? I only want about a couple of inches
Sep 4, 2015 09:27 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
