lift on the cheap
lift on the cheap
I have a 98 tacoma with 31x10.5 and the front rubs. I cut some plastics and still rubs when compressed. I thought about putting on cornfed 1" spacers to level out the front but they cost around $100 bucks. I found a 2.5 lift kit on ebay for $170. Has shackles and poly spacers. Not sure if it's any good but need to do something on the cheap. If I am going to spend $100 on 1 inch I think I might as well spend $170 on the 2 1/2 inch lift. Check out the ebay link and let me know what you think.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2427840082
dunno, the description sounds abit confusing. so is it really daystar? or not?....
i'd say if u want the cheapest yet most reliable for the price would be cornfed stuff... check out their site
www.cornfedsuspension.com
they have a special for free shipping!!
2.5" full kit Part # Taco-2.5" kit Uses Procomp EXP-13120 rear aal, new longer rear shocks, and the BPV bracket. Leaves truck about 1/2 in. high in the rear (similar to stock stance).
$250 with free shipping through the end of August.
3" full kit Part # Taco-3" kit Uses Procomp EXP-13120 rear aal, new longer rear shocks, differential drop kit and the BPV bracket. Leaves truck level.
look at their site as they have more info that what i just copied
good luck
lance
good luck
lance
Hey Pitch fork, Welcome to the forum. I'm in Abq too.
I have the 2.5 inch daystar spacers in the front of my 4Runner with no problems, they work fine (and cheap too)
We should get together sometime and go wheelin'
If your mind is really set on going cheap you can get the Daystar 2 1/2" front spacers here for $89.95 a pair.
www.central4wd.com
www.central4wd.com
Originally posted by Albuquerque Jim
Better than $89? That's pretty darn cheap, Where?
get the $89 spacer and a pro comp aal from summitracing for $40 and some longer front/rear shocks and youre set.
Jcrawl94
10
Oct 24, 2015 04:34 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
