kicking at high speeds
My 95 4runner v6, auto, starts to 'kick' or slip at highway speeds. It does it sporadicaly. Sometimes only a little bit and others it will do it for a few seconds and then stop. I use fuel system cleaner every 3,000 miles and the fuel filter was changed at 83,000 and it is now at 88,000. It only does it when in lock-up. It also seems to sluggish in 3rd. Is this injectors?
thanks,
Joe
thanks,
Joe
'kick' or slip
i think it is the tranny, but i am not totally sure. The rpm's stay at a constant level.
yes only in lock up, just normal 60-80 mph cruising on the interstate/highway.
the fluid in the diffs and tranny was changed at 77,000 miles.
From: Far western Kentucky (transplanted from central PA)
Sounds like a tad bit of fuel starvation... Will it do it at the same rpm when you're not in O/D? Just my 2 cents from a pinched fuel line problem recently (after the fuel gauge TSB work was performed...).
i don'y know, i will have to check. What is the cost to get fuel injectors cleaned, can i do it myself? Also, will itonly help it if i run 89-93 in it? I do get worse gas milage with the higher grade fuels. Very strange. Thanks for the help
it has been doing it. i thought it was 'bad gas', but i have filled up several times, on differnet octanes, and still the same thing. I do not drive on the highway alot, but when i do it does the dance. Do we think it is the injectors?
jumping at speed.
I've heard some talk about gas starvation or blockage you might think its a injector problem, could it be electrical... like the electrical cut out on some rental trucks or timming way adv. and your getting into trouble at high rpm???
It is hard to tell from your description, but it maybe the normal operation of the torque converter clutch locking and unlocking.
Gadget
www.GadgetOnline.com
Gadget
From like 70-80 it pretty much stays at 3,000 rpm's. If the torque converter was locking and unlocking, wouldn't the rpm's change? I was coming home today and the rpms were low(1,500-2,000) and it was starting to kick, a little, not as much as as on the interstate.
I am just not getting what "kick" means sorry.
I just noticed your signature and it says you have Jacob plug wires. Loose those things fast and get OEM wires.
Gadget
Gadget
a kick or a slip. not really a shake but it will move you in your seat. it is more front to back and than side to side.
Could it possibly be a pinch in the fuel like or just a clog?
FS[PacNorWest]: Kick panel speaker pods
AkitaDog
Jul 27, 2015 02:38 PM
