KC Back-Up Lights
Old Dec 2, 2003 | 12:25 PM
Fink's Avatar
KC Back-Up Lights
Has anybody tried those KC Back-Up Lights at Performance Products?
Here's a link:
http://www.performanceproducts.com/P...producttype=20
Let me know if you think they are with the 70 bucks and how easily they will be to wire up and their overall effectiveness.
Thanks guys,
Fink
Old Dec 2, 2003 | 01:00 PM
Darren's Avatar
I basically have the 5x7 equivalent and work very well. I would have to think the 2x6's would be similar and should work great. I can't speak to the wiring as I didn't do mine.
Old Dec 2, 2003 | 01:52 PM
Tacoma Dude's Avatar
Nah...
Check out Corey's aux. backup light write-up in the tech section.
50W each easily upgrade-able to 100W each.
All the parts should cost you no more than $20 for the 50W version at NAPA.
You could also try a local offroad shop if you got one... the local one here http://www.offroadwarehouse.com sells round and rectangular lights for around $12 each.
Old Dec 2, 2003 | 07:45 PM
Fink's Avatar
Do the lights from NAPA have all the wiring and instructions and junk?
I will check out Corey's write-up...thanks man.
Fink
Old Dec 2, 2003 | 09:23 PM
No, just the lights but Corey's write-up is pretty well detailed.
That was my first serious mod and remains to be one of my favorites
Old Dec 2, 2003 | 09:38 PM
blupaddler's Avatar
Thumbs up BACK UP
I bought the KC back - up light package for my T100 when I had it. Not from Performance Products, but locally. The cost was about the same maybe a couple of dollars cheaper, and I didn't have to wait for them to come.
They were super easy to install, it took about an hour, and I am not even that good at electrical.
Add to that it was probably one of the best mods I made to that truck, especially since I had a shell on it also. They really improved my backing ability.
robb
Old Dec 3, 2003 | 11:02 AM
Fink's Avatar
So if I were to get the lights seperately could somebody give me the name of the kinda lights I should get and what other wiring stuff I might need.
Thanks guys,
Fink
Old Dec 3, 2003 | 12:22 PM
Robinhood150's Avatar
I just got the cheapest lights I could find and that was some walmart fog lights for $14 for 2. It's not like you need expensive special purpose lights for backing up. If I were looking for driving lights or something, then yes, I would spend more money for good ones, but for backing up?
My walmarts are 55 watts each and make a nice wide beam that light up a pretty big area around the rear. It comes with wire and a switch, but I rewired it using a relay and a smaller 3 way switch. I can set them to be off, on, or come on automatically when I shift into reverse. I even wired up a little red LED light to come on when they are on. Search for a wiring diagram 'cause I know it's been posted before.
Old Dec 3, 2003 | 01:26 PM
Fink's Avatar
Awesome man, I will go to Wal-Mart and look for some...what size were the ones you got? I will probably get some rectangular ones so it will look a little bit better.
I'll be sure to ask you if I need any help with wiring it up or picking out the supplies. Thanks again man!
Fink
Old Dec 3, 2003 | 01:29 PM
kwando's Avatar
When wiring the lights where should I run the wire inside of the car without it leaking? Any ideas?
Old Dec 3, 2003 | 01:31 PM
I got these little oval ones, probably only 2 inches across. I do have to say that the paint on the housing is starting to chip off allowing it to rust, but I figure I can just paint them again later. And also, since the ones I got are fog lights, the light has a little yellow tinge to them. They've got other housing shapes that are white though. Tractor supply usually has cheap lights too.
Old Dec 3, 2003 | 01:34 PM
Churnd's Avatar
I just got some cheap driving lights from Walmart a few weeks ago to use as back-up lights. They were just $15, but do their job well. They're in rectangular housings and came with 55 watt bulbs. They're not super bright but definitely make a big difference in an un-lit area at nite. I'll snap some pictures tonite or tomorrow and post them.
Old Dec 3, 2003 | 01:36 PM
Churnd's Avatar
There are rubber plugs underneath the cab that are about an inch in diameter. When I wired my lights, I poked through one of those plugs. I used the one underneath my drivers seat. If you do that, it wouldn't hurt to seal it back up with some silicone afterwards.
ashersullivan88yota
Jan 18, 2022 05:37 PM
4.34runner88
Aug 11, 2018 10:44 AM
AkitaDog
Sep 1, 2015 08:05 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
