just did the deck plate and amsoil filter
Old Aug 8, 2005 | 08:12 PM
svtdriven's Avatar
I did notice a quicker throttle response from a stop. I am very pleased about that. seems louder, but not any faster. I didn't reset the computer or pull whatever fuse that I've heard about. would that make a difference?!
Old Aug 9, 2005 | 07:03 AM
X-AWDriver's Avatar
6-7whp isn't noticeable from the seat of your pants but it's nice to know you have a little more than all the stock 4Runners.
Old Aug 9, 2005 | 08:08 AM
rimpainter.com's Avatar
I could feel the difference before I was SC'd. So there!
Old Aug 9, 2005 | 07:45 PM
svtdriven's Avatar
Yeah, I only notice it when I first step on the gas, there is less hesitation. At this point, I am aiming for better gas mileage. I think my next step is an ignition system. Any reccomendations? And does my 01 4R have an intake silencer? I heard they exist, but I don't know where to look. thanks!
Old Aug 9, 2005 | 08:05 PM
Your stock ignition is pretty good. Coil-on-cyl is a very efficient design. Don't waste your money unless you start pushing enough boost to "blow out the candle."
Yes, you have an intake silencer on your 01. It is actually a fully replacable assembly midway down the intake pipe. You can replace it with a straight pipe and some barbed fittings (if you need them) for a bit better throttle response. Warning: when you pull the intake silencers, your open deckplate intake sound at WOT gets really loud. Too loud for some.
Old Aug 10, 2005 | 08:02 AM
X-AWDriver's Avatar
Ignition systems upgrades are a little over rated when you already have the coil pack design like Christian stated;my 1st gen Eclipse had the same type of setup and I was pushing almost 20psi on the turbo and the stock ignition had no issues whatsoever so even a SC'd Runner would never likely need one.
Old Aug 10, 2005 | 09:23 AM
MTL_4runner's Avatar
It's a spark, not a flame.
J/K Christian .....I agree with both you guys, stock ignition is more than adequate.
Old Aug 10, 2005 | 10:48 AM
Stop flaming me you big jerk!
Old Aug 10, 2005 | 12:55 PM
X-AWDriver's Avatar
It's called both at the dragstrip especially when refering to forced induction cars. Forced induction cars can create so much pressure that it sort of does "blow" out the spark but the term "blows out the spark" just doesn't sound right and flame sounds more "cooler" anyway.
Old Aug 11, 2005 | 12:00 PM
ilikesoup's Avatar
I have this exact setup (deckplate with amsoil filter) and i really noticed the power difference (up over 3.5k rpm's), unfortunately, i have yet to get a gas mileage increase because the sound at WOT (wide open throttle) is so sweet. I've been getting aroudnd 19 to 23mpg... i was about the same before the mod, with more conservative driving habbits.
My runner is a '96 SR5 with a manual tranny
Old Aug 11, 2005 | 12:09 PM
deathrunner's Avatar
I agree the stock Toyota ignition system is great, but I threw on a set of Nology plug wires and It definitely runs stronger. SOmething to think about. Don't know if they make em' for 3rd gens
Old Aug 11, 2005 | 01:41 PM
celica's Avatar
sorry to sound like an idiot but what is the deckplate modification?
Old Aug 11, 2005 | 01:50 PM
jtmaxx7's Avatar
Try putting the plate back on and you'll feel the diff. Feels like somethings holding the truck back. You have to push the gas a little harder to get the same response.
Old Aug 11, 2005 | 01:58 PM
Fink's Avatar
Use the search function or look in the Tech section under Performance. In short, its a hole that you cut in your airbox and then place a marine deckplate (a hole that has a threaded cover) so you can leave the deckplate open for highway driving or closed for off-road/water crossings. By far, the easiest, cheapest and in my opinion most worthwhile mod out there.
Fink
Old Aug 12, 2005 | 01:02 PM
javadoody's Avatar
i noticed the response right away with my personal deckplate mod and amsoil, but drive it a bit, the chip needs to learn the new input.
Old Aug 12, 2005 | 02:31 PM
Gangus2006's Avatar
Im getting 10-12 in the Runner city driving. With a 6" Deckplate and the ISR mod.
jasonty
41
Dec 23, 2018 01:00 PM
Iceman4193
Aug 28, 2015 08:43 PM
Toyvana
Jul 29, 2015 10:47 PM
jjrbus
Jul 23, 2015 05:05 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
