ISR mod and Deckplate Pics
Old Mar 6, 2007 | 02:17 PM
BMWToyotaMan's Avatar
Almost done with my isr and deckplate mod. Just need to make sure everything is cleaned out and reroute the vacuum line.
Old Mar 6, 2007 | 02:20 PM
04 Rocko Taco's Avatar
Wow, thats a really clean ISR....
Looks good...
For anyone who is interested in a CHEAP alternative, check here:
https://www.yotatech.com/forums/f2/newly-designed-isr-04-double-cab-100417/
Old Mar 6, 2007 | 02:24 PM
that pipe was about 10 bucks off of ebay I have had it for awhile and just decided to use it. For about 20 bucks you could do the same thing, I did have to cut the pipe a bit so you would need some type of saw to do the same.
Jeff
Old Mar 6, 2007 | 07:58 PM
Elton's Avatar
looks great
Old Mar 7, 2007 | 10:58 AM
it sounds quite nasty now.
Old Mar 7, 2007 | 03:10 PM
Elton's Avatar
mine sounds even better with a trueflow filter
Old Mar 7, 2007 | 04:18 PM
HUTCHSTACO's Avatar
i have a trd filter for that i will sell cheap...make a resonable offer...20 shipped
Old Mar 7, 2007 | 04:21 PM
rimpainter.com's Avatar
Let's race.
Old Mar 7, 2007 | 08:14 PM
ha, yea right. Let me finish my custom turbo kit then we can race. Cant loose on 22psi.
Old Mar 8, 2007 | 10:46 AM
Shoot, with 22psi you'll be lucky to have any traction!
Old Mar 8, 2007 | 11:09 AM
OSU4Runner's Avatar
Looks good....whats up with the white deckplate though? Did they not have any black? I got mine over on laskin road and got the last black one they had. But, ya definately add a true flow and it will sound awesome
Old Mar 8, 2007 | 12:42 PM
Baloo's Avatar
Originally Posted by 04 Rocko Taco
Wow, that's a really clean ISR....
Looks good...
https://www.yotatech.com/forums/showthread.php?t=100417
I have seen this one before and if you don't want to have to cut into the existing tube, it seems like the only way.
Do some people remove the J tube as well, capping the remaining hole, or do they just leave the J tube intact? Would it help one way or the other?
Old Mar 8, 2007 | 01:13 PM
I've seen the J tube taken off, but I figure, if any water does get in my WIDE OPEN deckplate, that the J tube may help catch it. So I kept it in!!
Old Mar 8, 2007 | 01:31 PM
Tacoclimber's Avatar
FWIW, I capped mine. I want the water to go straight into the intake.
Old Mar 8, 2007 | 01:59 PM
No J-tube = .236879HP.
Old Mar 8, 2007 | 02:01 PM
Well, every little bit helps...
Old Mar 8, 2007 | 02:18 PM
Baloo's Avatar
Thanks. (I think)
Old Mar 8, 2007 | 03:17 PM
Bodock's Avatar
Hello,
I'm new to the forums. I have a 2000 2wd sr5.
I performed the ISR mod on mine tonight.
Check it out.
Old Mar 8, 2007 | 03:57 PM
Originally Posted by Bodock
Hello,
Check it out.
Dang, first post and not only is it a mod, he posts pics, too! Welcome to the forums!!!!
Old Mar 8, 2007 | 07:59 PM
Hello,
Check it out.
Wait, is that ISR tube going over the stock intake tube? Either way, could you find a piece that eliminated that bottleneck in the middle?
Welcome BTW!
