Interior lights 86 yota
Am i killing you with questions yet?
what sort of interior lights should i have on this 86 truck? the instrument lights are the only ones that are on now, but i wanted to know if the heater control should light up and if i should have a courtesy light when opening the door.
i havent had a chance yet to troubleshoot anything yet. just wanted to check with the pros
thanx ya'll
brad
thanx ya'll
brad
You should have lights at your heater controls and a courtesy (above your mirror) light. You probably have a 3 position switch on your courtesy light that is: up=on all the time, middle=off all the time, and down=on when door is open. I have several of the mid-80's trucks and it seems the "on with door open" light doesn't work on a lot of them.. Maybe a bad switch in the door? I think the SR5's of this era also have map lights up by the mirror also.
Originally posted by EWAYota
should i have lights on my heater/fan position settings too? 94 pickup?
Originally posted by barkeywayne
Yes. If your dash light/instrument panels lights are working it's probably not a bad fuse, maybe a bad bulb/LED or loose connection to your heat/fan panel.
Yea, mine worked intermittently (light would go off when I slid a knob) about until about a week ago when they just stopped working.
I'm going to do the blue dash lights mod, so I'm not too worried about it.
Same story here, my '90 just lost climate control lights, my dash lights went out a year ago but i just wired past the rehostat and they were fine. I am planning on the Led mod soon as well so i am ust gonna ignore it for now.
The climate pannel lights on my girlfriends 87 corolla always need a little knock to light up...
I just lost my dome light recently... not the fuse, door switches or the bulb, does anyone know where to look?
Originally posted by jx94148
If you can't get the dome light to work with the door someone may have cut the door switch wire to kill the annoying key in/door open buzzer. I did and lost door/ dome on the drivers side. Right side switch will light it though.
Jun 1, 2021 01:51 PM
HookahRoo
Jul 20, 2015 07:06 PM
