integration relay/ power lock install
I have a 99 taco that came stock with no power windows, door locks or power mirrors. I recently bought all that stuff of ebay and was able to install it all in my door(actuator, regulator, switches and mirrors). the mirrors and winows were prety self explanitory, hot in, componentry, ground out. simple. the power door locks are entirely a different story. I have a wiring diagram for them but I don't know how to post a pic of it because it runs off some special but it basically shows a hot running into my intergration relay and then a bunch of wires coming out attaching to componentry and junction boxes. it shows nothing of what's going on inside the integration relay. all the wires it shows coming from the intergration relay are occupied by other colored wires. is there any I could buy another intergration relay and set it up for my locks? I know that an intergration relay has a lot of logic and cannot be duplicated easly, it involves diodes and resistors and etc. can anyone halp? I don't really care if this is hooked up correctly, just as long as it works propwerly, thanks.
all you need for a relay is your basic relay from any parts store, and they should have a diagram they of what you need to do, i put power locks in my pickup about a year ago but i cannot remeber what the diagram looked like, sorry, i will try to find some more info
cody
cody
if you could show it to me or describe it it would really help. I know that what i need has some logic behind it because it's supposed to be that if you turn the drivers side key twice to unlock it is supposed to unlock buth doors as opposed to unlocking it once to just open the deivers door, there has to be some sort of sensor for that
well i thought that you would be using an alarm or a remote lock system with your truck, i have no idea how to install a factory lock system that you are looking for, i would assume that you would need a device inside your actual door lock with relays but not sure sorry that i can't help
cody
cody
Jun 1, 2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
Jan 16, 2016 06:38 PM
Johntom240
7
Jul 13, 2015 12:18 AM
