Installing Hitch have questions....
Old Jan 24, 2004 | 11:41 AM
nm4runner's Avatar
Question Installing Hitch have questions....
I have a hitch that I got off of ebay and the place where i got it took off the sides for easier shipping. To install the hitch do i need to put it together first, or can i put one side on bolt it up and add the middle then add the other side...thanks in advance
Old Jan 24, 2004 | 11:59 AM
My99's Avatar
I have no idea, but it probably doesn't matter. However, if you must drill into the frame, I would definitely assemble it first, you wouldn't want to get your measurements wrong.
Old Jan 28, 2004 | 11:21 AM
ALBPM's Avatar
I agree with My99.
Also you will find out if you need any exrta hardware before you tear into it.
Where in NM are you???
Old Jan 28, 2004 | 01:12 PM
steelhead's Avatar
Re: Installing Hitch have questions....
I would probably go for putting each side on and then the middle part last. It may be a little work getting it in there but at least you won't have the weight hanging on one side while trying to get the other installed. my .02
Old Jan 28, 2004 | 01:17 PM
rjm's Avatar
rjm
Old Jan 28, 2004 | 01:21 PM
amusement's Avatar
Please make sure the bolts are grade 8. Grade 5 bolts are not strong enough to endure towing.
I would put it together first, but don't tighten the bolts and nuts all they way.
Old Jan 28, 2004 | 01:27 PM
Robinhood150's Avatar
If it's a bolt on, no drilling, then bolt up the pieces 1 at a time...but leave it loose so everything still fits together easily. Once it's all together then tighten everything down to specs. Otherwise, you're either in for a workout or it's a 2 person job.
Old Jan 28, 2004 | 01:57 PM
I just installed a new 3 piece hitch on my '90 this weekend and ran into the same problem. Definetly take it apart before you go through the hastle of trying to muscle it in youself or even with a buddy. My side pieces were shaped in such a way that you needed to slide them in from the bottom to the top at an angle. It would have been very tricky to do this with it assembled. Plus as others have stated in this post it will be easier to leave all the bolts loose until you are ready to button it all up.:pat:
4x4-runner
Apr 18, 2017 09:08 PM
dropzone
Aug 11, 2015 05:16 PM
58rennur4
Aug 4, 2015 08:49 AM
TJWilly
Jul 31, 2015 02:05 PM
defrag4
Jul 31, 2015 10:50 AM
