idle,brake question
Old Nov 21, 2003 | 06:40 AM
Mr.Spock's Avatar
idle,brake question
I do a search before asking and i did'nt find very explicit answer to my problem.
My 91 22re 4runner idle erratically(sorry for my bad english ,i usually talk french).
it's idle up and down 700-800-700-800......
very embarassing on a red light.
when i push brake the problem it's even worse.
vaccum problem,??
injection??
I already clean de TB.
any help will be appreciate
Old Nov 21, 2003 | 06:54 AM
Arnold's Avatar
This link might be of help,
http://www.geocities.com/toyotashawn/bizzareidle.html
Old Nov 21, 2003 | 09:07 AM
mtnfreak's Avatar
What's the normal idle in Park / Neutral? Any work done recently? Does the cold start injector seem to be working normally?
Old Nov 21, 2003 | 09:56 AM
Mr.Spock's Avatar
When the motor is cold the idle is approx 1500
when is hot is approx 750
the cold start injector seem to work properly.
No work on the truck (stock)
i have a code 21 (o2 sensor) but i drive like that for about 3 months and i never had this idle problem before.
the exhaust pipe is broken just before the muffler.
thanks
Old Nov 21, 2003 | 09:57 AM
Mr.Spock's Avatar
Thank you Arnold for the link
Old Nov 24, 2003 | 05:06 AM
Mr.Spock's Avatar
Bad news for me :pat:
I think i have a leaking head gasket.
I lost coolant and white smoke goes out form the engine but i don't see any leaking hoses.
I think it's why i had a strange idle.
please somebody can confirm??
thanks
Old Nov 24, 2003 | 06:12 AM
CTB's Avatar
CTB
Ya, a blown head gasket can cause a rough/sporadic idle. Are you burning coolant?
Old Nov 24, 2003 | 06:53 AM
Mr.Spock's Avatar
yep it's burn coolant
maybe my temp indicator is broken cause it's never been on the "red" before the problem.
just hope the head is'nt cracked.
thanks a lot for your answers.
$$$$$ again
Old Nov 24, 2003 | 09:18 AM
PirateFins's Avatar
thanks
I adjusted my idle down and it took care of the eratic idle problem.
Coolant in the oil, white smoke huh. Have you ever looked at/ changed your timming chain and guides? The plastic chain guides tend to eat themselves, alowing your chain to go slack and wear a groove in the housing, right at you guessed it, the water pump. The housing cracks and lets oil in the coolant and visa versa. Check that out first before having the head torn apart.
Old Dec 1, 2003 | 05:24 AM
Mr.Spock's Avatar
Hi all
I had remove the head this week end and i effectively have a blown head gasket.
Someone had problem with the 22re head gasket?? because the ex-owner of the truck told me that he changed the gasket 3 year ago.
Is it normal that i had to change it again??
Anyways i had buy a kit and i will change every seal and gasket on the motor.Will be a good thing .
Great kit !! for 109$ i have Head gasket,intake and exhaust gasket.valve cover gasket ,egr gasket ,o-ring for injectors,valve seal,grommet......i forgot some
thanks for your help
Eggslinger
Jun 8, 2019 03:32 PM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
Jnkml
Jul 6, 2015 01:20 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
