IAC vaive flow direction?
Old Sep 3, 2003 | 10:44 AM
Supercharged's Avatar
I know that this has been discussed before, but I am still a little confused about which way the flow goes. My valve did not come mark as illustrated in the manuel, so I took a guess that the flow goes from throttle body towards the manifolds- not the other way around. Am I right or wrong?
Thank you for your inputs.
Old Sep 3, 2003 | 01:42 PM
White SR5's Avatar
TB to engine
You're right. It should open when air flows from the TB to the engine. Close when air comes from the engine. I had a similar issue, only I just didn't have the IAC check valve and picked up a PCV valve from Pep Boys. Works fine.
Zach
kawazx636
Oct 6, 2021 03:03 PM
Steven.m.paulk
Jun 7, 2020 10:45 AM
live4soccer7
May 11, 2016 06:52 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
