I need more pulling pwr from a 91 4x4 pickup V6
Old 06-15-2003, 02:56 PM
Arfball's Avatar
Unhappy I need more pulling pwr from a 91 4x4 pickup V6
I have been very disappointed in my Toyota's towing
performance. I have heard the following comments when asked:
1. your engine is junk, buy a new truck
2. Toyota makes weak engines
3. I can't get toyota performance parts for that year.
4. Your engine can't handle many upgrades.
I have a magnaflow muffler and 2 1/4 cat back piping, but I don't feel like that improved my towing at all. I lack knowledge with engine work and get very nervous to do anything. I like my truck other than that. I also can't afford a new one. I would rather modify it and save myself the money if I could. I have also considered a new 3.4 liter engine. What are my options without spending a whole lot of money.
Thank you!
Old 06-15-2003, 06:22 PM
Los Gatos?'s Avatar
1) You don't WANT to buy a new one. It's not weak because it's old, it's weak because they were weak when they were NEW
2) If you want to do a swap, do a Supra turbo swap with the 7MGTE engine. The entire swap is cheaper than a new 3.4L.
3) Get headers. Do the ISR mod. Do the air box mod. All of these mods can be found in the tech section of this website.
Old 06-15-2003, 09:06 PM
You didn't give the details of your truck!
What changes have you made to it?
What year/model/engine/trans do you have?
Did you go with larger tires without regearing?
I tow a 2 place covered snowmobile trailer that is like a moving wall, very unaerodynamic. I have towed with a '91 Xcab 22re powered 4x4 truck with a 5speed, and 4th gear was the only option on the highway. Sometimes 3rd would be used for steeper hills. I would maintane 65mph usually.
Now I use a '92 4runner with a 3.0V6 auto. While it's got more power than the 22re, the gearing and auto trans sucks some of that power away. I do not use overdrive when towing, no one should really, and can usually do 75-80mph on the highway with the same trailer and load. I get about 10mpg when going that fast though!
Give some details of what you have and what you're trying to do.
Old 06-15-2003, 09:22 PM
its2slo's Avatar
change your gears, it will make a huge difference!!(even if you run stock size tires). also mod your air box/intake to compliment your exhaust system, check out the tech section for that.
Old 06-15-2003, 10:39 PM
AgRunner06's Avatar
Post
Dang. How many rpms are you running at that speed?
Old 06-16-2003, 07:15 AM
At 80mph, I think it's around 4000rpm. That's alot under a load, but that's where the power seems to be. I noticed some oil burning at this rpm for the miles I'd tow, like 100 miles at a stretch minimum.
If you ask my tranny guy, he'll tell you no automatic built today should be used to tow in overdrive. So, I burn a little more gas and save the tranny!
Old 06-16-2003, 05:47 PM
Arfball's Avatar
My engine is a V6 EFI 3.0L
How can I modify my air box and what and were do I get this stuff from. I would also like to know more about the supra engine and gearing. Approx. cost and where to take it. What kind of out put will it give me?
Also, I have a magnaflow exaust with 2 1/4 inch piping to the converter. Is there a big difference in the performance from other manufacturers? I need to fix this thing up. I do tow in 4th gear as well and have a very hard time when I hit little bitty hills.
Thanks for the help!!!!
Old 06-16-2003, 07:00 PM
Firefyter-Emt's Avatar
The only way to get any "pulling power" out or her is to add a winch.. Sorry buddy, even with all the mods you are going to get poor towing performance and the mileage of a Ford V-10. I tow a 2k + pop-up and it pretty much sucks if you tow for a long time.. (I will be doing 2k in towing miles this mont for the rally and a trip to VA near the TN boarder..) I will suck and I have to live with it. If you want to tow with the 4Runner, you made a wrong choice in tow rigs.
Old 06-16-2003, 07:11 PM
bryontro's Avatar
Sorry buddy, these guys are right. My 92 which I love is a lot of things but a tow vehicle it is not. My 95 grand voyager could (traded lately) tow circles around my toy. I could't belive it either but it is true. I have 170,000 on my 92 with a 3.0. To say it is junk would not be my opinion. Weak yes, junk no. Good luck.
rondogracing
25
12-11-2015 07:26 AM
Dylan199119
06-25-2015 09:54 PM
shadowbirdie
06-18-2015 06:38 PM
Mohamed
09-01-2002 06:25 PM
Quick Reply: I need more pulling pwr from a 91 4x4 pickup V6
