I need help to clear 285s for cheap
Old Oct 4, 2006 | 09:07 AM
AH64ID's Avatar
Originally Posted by Tacoclimber
Whew...for a second I thought I was on the wrong forum board...
did seem kinda like pirate for a minute didnt it
Old Oct 4, 2006 | 09:52 AM
AxleIke's Avatar
Originally Posted by RunnerUp
hahaha i wonder how much cutting you would need to do... someone try it
2-3 inches should do it just fine. The rear is tricky because of the door. Us 2 door folk don't worry too much about that. Chop it, and be done. If you cut enough, you can get 35s under there. Still might rub the rear by the door though.
Old Oct 4, 2006 | 06:01 PM
AH64ID's Avatar
A 285 is 1.2" taller than a 265, therefore only .6" taller on the radius, and only 3/4" wider, so if you trim it wont need to be much, and probally only on the pinch weld...
Old Oct 4, 2006 | 06:06 PM
AxleIke's Avatar
oh definetly. But just to be safe, and to give the truck a rakish, macho look, trim 2-3 inches. It should be good.
Old Oct 4, 2006 | 07:45 PM
  #25
TX-BLKRUNNER's Avatar
uh, no one has mentioned anything about the upper control arm. does no one have a problem with 285's bulging and hitting those? also i have to dissagree with the statement about the spacer lift not allowing for larger tires, i rubbed occationally with 265 75s on stock susp but when i did the spacer lift i never rubbed any where period
Old Oct 5, 2006 | 05:14 PM
  #26
wjwerdna's Avatar
hmmm... spacer lift and 285's for me... no problems... though it is street tread.. upper control may rub with off road tires
Old Oct 5, 2006 | 10:11 PM
  #27
Patsawasy's Avatar
back to do some reading i go. thanks again
Old Oct 5, 2006 | 10:12 PM
  #28
Patsawasy's Avatar
rather MORE reading
live4soccer7
May 11, 2016 06:52 PM
Davebarbier
Nov 3, 2015 03:28 PM
alexcarey
Oct 14, 2015 06:05 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
charlie_fong
Sep 27, 2015 10:06 PM
